Hi Guys,
I have asked this question within other threads but have not got any replies, so I thought I would open it up to the wider community to see what response I get.
Does the R33 GTS-t have any camber adjustment from the factory? I have lowered the car and now have about 2degs of negative camber, causing the insides of my expensive tyres to wear faster, no good for my wallet.
The other question I have is whether when drag racing anyone bothers to have the camber wound back to neutral, to keep more rubber on the road, or am I worrying too much?
See'ya:burnout:
https://www.sau.com.au/forums/topic/7176-camber-adjustment-on-r33/
Duncan,
Yeah I've just had it done, there is very little in the way of camber adjustment, probably only 3/4 of a degree, so I may need a camber kit for the back if it's possible.
And yes you were right it was the toe in that was causing the wear on the rear tyres. Hopefully now I will get better traction for the drags, and reduce tyre wear. Hey wait.. aren't those two things mutually exclusive.
Thanks Duncan
See'ya:burnout:
dude,
You need adjustable top control arms (for d' camber) front, they go for around $500. Rear camber kit (bunch of different bushes and sleaves) bout $100.
While your at it you could do the adjustable radius rods for a bit of extra camber, for turn in and less nose dive under brakes.
Rev210,
Thanks for that, I knew somebody had to know about it. I take it I can get this sort of stuff through Whiteline? I was only thinking about doing the back, but if I want to race it then I probably should do it all?
Thanks for the help.
See'ya :burnout:
Originally posted by GTS-t VSPEC
Rev210,
See'ya :burnout:
They would be a good start.
If you can't get everthing from them let me know. I'm sure I'll remember who it was that does the different bits:cool:
Thanks, I think after this Wednesday I'll start off with the pineapples everyone is raving about and then start to improve the overall handling. In general I want the car for hard cornering and race tracks, but I'd like the occasionaly drag race. Is it possible to have both of these setups?
See'ya
:burnout:
Talking of suspension set-ups here's my compromise btw straight-line drag grip, all round driving & cost!
Rear camber - less than -0.5 using a Whiteline camber kit + the factory adjustment. From the factory you get -/+0.75 of adjustment. The Whiteline c/kits allow an additional -/+1.5 (via 2 kits) I only needed 1.
Front camber - -1.2
Whiteline rear subframe align/lock kit
Whiteline blade adjustable sway bars front & rear
Kings "low" springs (30mm lower than stock)
Standard shocks - I'd like to upgrade these but it's not on the list of priorities, in fact the shocks aren't too bad! Even the suspension workshop that I had do one of my alignments commented that my standard suspension components all appeared to be in good condition! Maybe those low kms are legit'!? Doubt it :D The standard shocks "should" also help with weight transfer upon launching.
All of the above changes have had some positive effect on my cars handling, mostly straight line grip!
BUT........ Without a doubt the biggest improvement to rear grip levels was fitting top quality tyres!
GTS-t VSPEC - In answer to your last question (in your first post) I don't so much as dial out the neg' camber but set my rear camber fairly neutral all the time. This way both rear grip & tyre life is maximised :P
Race track suspension? I haven’t got a clue in that dept’ ;)
Hicks,
She's more likely to vomit into your lap, and you having a 10sec car, I'd like to see that!
whatsisname,
Thanks for all the info. I currently have coilovers, which dropped my ride height, and at maximum factory adjustment the camber is still -1.3deg on the back, I'd prefer it to be neutral. I'll take what you said onboard, and hopefully when I have some more money I can start to get serious with the suspension and handling.
See'ya
:burnout:
GTS-t VSPEC,
-1.3 rear camber is about the same I had prior to the Whiteline kit (after lowering 30mm).
Lowering more than ~30mm without a camber kit ='s uneven tyre wear.
The Whiteline camber kits are cheap so it's easy fixed :(
Looking @ the level of engine modifications your car has/will have I'd be aiming for minimal r/camber! Unless you want plenty of :burnout: :D
Matt
whatsisname,
I think we dropped the height by 25mm or so, and are on the limit of the factory camber adjustment. The camber kit sounds the go, I just wanted the neutral camber to get more grip for drag racing.
I definately don't want :burnout: as I have expensive tyres normally.
See'ya:burnout:
Whatisname.
G'day Matt, how's things??
Hay can you do me a big favour and measure the distance between the middle of your wheel (front and rear) and the lip of the top of the guard.
I'm changing the suspension set up on mine soonish and need to know what the factory height is. I know that yours is 30mm lower than factory it'll give me a good idea.
Thanks
Jayson
G'day J,
Things are good mate :)
Yeah no prob's dude. I'll take some measurements & let you know shortly.
:D
Edit: I've had a quick look. Here's what I got.....
Front - ~340mm
Rear - ~332mm
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
    • For race cars, this is one part where I find having the roll cage bar having gone through a hole in the floor better than the build it up on a ledge inside... The Merc I help on, the main hoop ends are marked on the car, and the jack is marked... Jack goes under a few inches and lifts one whole side of the car up... Removes that fight for long slim jacks for race car duties!   My biggest issue for the daily drivers I work on, is my jacks don't go high enough. The jacks start out on a few blocks, jack it up, then start a second jack under it on more blocks, and then I can get an axle stand under it. My axle stands are presently in use, and are nearly fully extended. The car is sitting with barely more than a cm of clearance to get the wheel off the studs! Sarah's Kluger is the same, as it has an ungodly amount of droop available in the suspension and a distinct lack of good jacking points!
    • Happy? Yep, my to do list is getting shorter and shorter. Either this light approaching is the end of the tunnel, or I'm about to be hit by a train... Ha ha ha   Also, Duncan isn't that far out of town that you need to make a multi day drive out of it. 😛
