Hi,
I have decided to get new wheel's, had enough of my 16'" looking for decent 17" or 18's
Does anybody have a pair around the house before I go to the tyre shop? :(
Looking for a package with tyres..... but will not say no to a nice set of mags as standalone
sexzila
https://www.sau.com.au/forums/topic/71942-looking-for-new-mags-for-my-zila/
i 'was' thinkin of selling my 18" work rims, and get some 20" bling bling chrome rims.. but didnt have enough time to look before i needed new tyres :cheers:
www.tempetyres.com.au cheap cheap rim and tyre packages.
Can you please send me an image of the wheels . [email protected]
Thanks
Al
if you get whats on the rim, they're Toyo Trampio tyres. I just got a set on mine. Very nice tyres so far. It cost me about $1100 for the set which is cheap.. if the rims are not much more than that and the tyres are in good condition, sounds like a good deal. Even tho i also dont really like tri spokes, personal preference tho...
hey mr zilla, are you interested in Buddy Club p1 Racing 2 with s03 all round on 18?
Hey Erik.
Long time no c :)
Can you email me the images and th eprice thanks:)
[email protected]
How's the car going? Will have to take a photo of it one day when I catch up with you.
I like yellow :)
Al
Hahaha, yeah haven't meet you for a long time.
I'll send you piccies today, if you want to see the rims. You can do it as well.
Car is going fine, nothing has change.
:) I wanted to see your creation again someday, like my old one :)
Erik
Cool sounds good, the other black car of yours is in my folio and when I do the interviews people ask about it......
Hi Al
I sent the pictures already.
What interview al? You got the piccies in your folio? I don't get it
When I go for job interviews as a Graphic Designer people always ask me about the car on the banner and I tell them it was my friends car before he got a new yellow :)
Most people haven't seen R34
And that banner is 3m long .... :D
Are these your wheels?
And can you post the price.
Thanks Erik
he wants 1500$, i said click the link that i posted for more info, they are not mine so i dont have much info but i thought ide post em to help you out anyways.
Sorry Ramis,
For that much money I can find a new package with tyres :(
At the moment looking for a nice white set of mags :P
Or anything else if I like it :D
    • f**king around with the bro
    • Ludenham   44.2 tops day no issues
    • Then today, I went to visit a man with an r33 hat Peter and Road and Race sorted the alignment. As it is being set up for general track/hillclimbs etc it has a heap of caster (7o), less camber than I am used to (1o front and 2o rear, as the caster looks after that in turns without the braking downsides), 3mm front toe out and 0 toe rear. Will see how that goes and track tyre wear to see if it does need more camber, but adjsustment is also limited with nismo arms and adjustable bushes at only 1 end. It does have a bent inner tie rod on the driver's side front but as it came up within spec I'll just leave that as is. So, that is getting close to my chapter of this story....could of tidy ups then a shakedown in early October before it finds a new home.
    • So, it went to Unigroup for a run in and tune on Friday, everything went (generally) well. In terms of fixes, the engine was good and there were no leaks. It needed plugs (I hadn't checked them because the coil pack cover was on a new engine and I couldn't imagine they weren't new.....but turns out the temporary plugs to just keep it sealed up were in there.....new plugs gapped to 0.8 and it was fine from there. Also, there was a little preload on the clutch slave which caused some slip. I haven't had the box off so I don't know what the clutch looks like; my guess it is brand new and the pedal had not been adjusted....backed that off a bit and it held fine. Last thing will have Dose crying....the idle especially when cold is a bit difficult between the cams, forward plenum, atmo blow off valve and an 80s air management system. It is fine when hot but a little uneven when cold, will see if I can sort or at least improve that one cold morning. Other than that, tuning went fine. It made 245 but was pulled back to 227 which 2 opportunities to improve in future. 1. The factory CAS is not great and was jumping around at high RPM, so Mark took 2 degrees out up top (that is why it stops making power and lost 20kw). Very safe this way and the extra power is available but will require a more modern ECU and better cam (or even better crank) sensor 2. The 2871 in factory housings is very big for a low mount, and the internal wastegate is too small, so it was creeping from mid range all the way to redline....the duty cycle on the boost controller is turned down a little for safety. That is much harder to fix, it would need a large external gate and that would require a whole bunch of other changes, so it will go as it is for now. It feels nice and healthy and safe, so should be good for about a billion laps like this.
    • what sort of caliper are they? If they are a slider and you gave everything a good clean, you might need to regrease the pins. My guess though is they will come good after some abuse as suggested above
