in my 1990 r32 GTS-T m spec i have a couple of buttons which i would like to know abit more about, the first is a button next to the steering wheel on the left side it has a picture of a small and large fan with a green light and the other is the button on the window switch block that flips the mirrors in, on mine only the passengers side is this right or are both ment to turn. thanks for any help
https://www.sau.com.au/forums/topic/72094-r32-buttons/
Ok, the first switch is also in my "Super-Hicas ' Silvia (an up spec S13).
Now I believe this to be a 'de-ioniser' with hi/lo fan setting. You can actually hear the fan spin when the ign is on (engine off, all ign lights on), and your parked in a quite area. Do you also have that big plastic hump on your rear parcel shelf?
Hope I'm right with this???? (I got this answer off these forums!!)
Secondly, with your 'fold-in' mirrors, they are both supposed come in/out at the same time!! (for sure!!) These things do fail sometimes.
You can actually try to service these yourself (they're expensive to replace, let alone find the right colour!!)
Tricky, but sometimes a good clean and wiring check sees them going again!!
Hope this helps, and the ioniser info is correct!!(?)
https://www.sau.com.au/forums/topic/72094-r32-buttons/#findComment-1327963
ok i'll have a look for this lump on the parcel shelf hopefully the fan works, maybe it was too noisy to hear it workin before, plus does that mean i have another oil resevoir for the HICAS in the boot or not. plus does anyone have any wiring diagrams for R32 just to help me out for the future. thanks
https://www.sau.com.au/forums/topic/72094-r32-buttons/#findComment-1327999
Hi M32.
Hicas and that switch have nothing in common....first up!! It's a 'comfort' type of control.
It was just that the 'super-hicas' variants tended to have these more up-market' extras, like that 'fan switch'.
No resevoir in the boot for Hicas.....that I've ever seen....electric, unless it's the earlier version (which you may well have!!) or 4WD?
Yep, a nice quiet location and you'll hear the whirring sound of the fan.!!
R32 wire diagrams are available on this site.....somehere!!
All the best and tell us what you see (hear!!)
https://www.sau.com.au/forums/topic/72094-r32-buttons/#findComment-1328352
    • That was the first session so not a lot to take from the day. It was low 20s ambient and the coolant had got to 110 (and obviously had some pressure!) so that still needs to be addressed. I haven't downloaded the data yet but will. I had refilled the auto trans with Redline DT6 because it claimed the best viscosity I could find at 100o. It wasn't really long enough to get a good feel for that; while the trans got to 100o in the session it still wasn't shifting crisply as I hoped. I think I'll try a few more sessions before judging. No steering motor overheat but I'd hope not in only 1 session! But finally the suspension; it was night and day over the standard stuff and the car was a couple of seconds quicker on the same crappy tyres, which is a huge difference. I'll stick with that and get some sway bars and a mechanical diff sorted too and see how that all goes together
    • I guess it’s partially a compromise of how my car is used, wanting to be able to switch from drift to grip with track side on-car adjustment. Also partially with the way the knuckles are set there is more static camber but less dynamic camber gain.
    • OK, so update from the track day on Friday It was a classic "an unfortunate series of events'. There were a few cars around and when i checked my mirror coming out of the fish hook I notice some smoke from the rear of mine. Looked again and it was getting much worse, I figured I'd blown a turbo or something to got off it and pulled off the racing line. However.... since it is a left hairpin into a right kink, I was on the inside of the next corner. There was a car passing me on the left and a big drop off over the ripple strip on the right......and someone had knocked the witch's hat that was on the apex about 1m onto the track. So, between those 3, I decided to mow down the cone and not damage my car/the other car. Right choice, but surprising result.  The car decided the cone was a small pedestrian so it blew the rear bonnet hinges up to protect their head in the upcoming person to car impact....I didn't see that coming and like an airbag deployment it happened super fast. Straight into the pits from there, everything was driving fine but it became clear it was a coolant leak not smoke, it was billowing up onto the windscreen. Onto the trailer and home. I'll do a separate thread about the repair (once I work out what it is ), but the immediate problem was the bonnet wouldn't open because the front was pinched onto the front bar and would not release. Ultimately we unbolted the hinge from the bonnet, pulled it back a little and it released from the front OK. "There's your problem", the top radiator hose had popped off at the radiator.
    • Yeah that looks like great caster, but I'd suggest trying less front camber some time and seeing if it helps with braking without reducing mid corner speed too much
    • I ended up setting the rear 5mm higher than normal to give some clearance.  My plan is to run the least camber I can in the rear which I think with the extra width is going to need to be -1.75 to -2.00° just to get clearance.  Guards have been rolled and pulled as much as they can/I would be wanting to.  front has the Acostal knuckle with the KPI change and the drop etc. So should be okay with the existing settings I have run with AR1s etc Front: Toe total -2mm(1mm out each side) Caster +7.5° Camber -3.8° Ackerman +15°
