Does anyone know were I can get some side intrusion bars made up for my cefiro?
I only know of a place in queensland, ISASO engineering, that was mentioned on another thread, but he has been putting his prices up since his demand has obviously increased
Would prefer someone local to Perth, but anywere is good as long as its cheap
https://www.sau.com.au/forums/topic/72639-side-intrusion-bars/
C-red did the compliance on my Cefiro and I believe they got the side intrusion kit from ISASO aswell.
JK
Yeah, the guy at ISASO just said i could bolt them in with high tensile bolts.
Any chance i can look at yours sime time soon JK
I just need to measure up the length of the bars so i can get mine cut to size.
Would be a handy way of cutting down people's cost in getting them installed
THey quoted me $1000 to get them installed, they only cost $500 at the max to buy
and 2 hours of your time to install
how easy is it to drill a hole in a door and bolt them up?
Im going crazy
its taking me forever to get my car on the road
I just spoke to steve from isaso and he doesnt make them anymore
Great timing
if anyone is able to measure theirs up and let me know how long they are i would greatly appreciate it
Theres no way Im taking mine out... but youre more than welcome to have a look how they are designed. They arent just 1 piece of metal... they are layered like my top view below:
_-------------__
This allows the bar to go inbetween the door seam... and then you can bolt it in.
JK
Yeah, i looked in my dodgy old gemini and they have the same thing. Wasnt sure if it was the same for new cars.
Would appreciate it if i could have a look
I just got measurements of a guy at ISASO, but he told me they needed and end bracket to bolt them in
just really need to see what the brackets look like
Please email me or send me a text when its alright to look at them
041 994 6415
[email protected]
Hey there
place in adelaide does what ya after $120 a pair and his work is top quality used them in my two cefs and a 32 with no troubles theyre the weld in type though which i personally think is better :werd:
Adelaide compliance centre 0427717686 sorry only got his mobby number :( have fun wit it
  • 6 months later...
mate used to make door bars heres what you do get two round bars one about 30mm diammeter and one to fit insid it make them atleast 3mm wall thickness measure door lenght cut bars so they will overlap at least 300mm more is better then cut two bits of flat bar 3 to 5ml thickcut them big enough to weld flat on end of bars drill holes in for bolting slide bars together fit in door slide bars out to ends bolt them up and weld join paint and your done . make sure you can weld or get them welded properly or they wont pass as they are there for a raeson good luck.
    • Ok I get you. But isn’t the butterfly intake a headache with the +T?  see this is my plan so far but please advise me into the right direction.  Nistune Ecu, 1000cc Bosch injectors, TD05 or TD06 Kinugawa turbo using stock rb25det exhuast manifold, walbro fuel pump unsure of model I think it’s 450/460, spitfire coils and sparks to suit and a R35 MAF sensor and boost sensor.    I was thinking maybe do a cheap eBay plenum $400-500 or try find a stock det neo intake. I think I’d port match it so it’s getting the full capacity but open to advice please.  Thanks
    • The issue now is the 'fuel cut' while driving, and when it happend, it does not stall. This, I did not test the fuel pressure while driving as I cannot with a fuel pressure gauge. I do have Nistune logs, yes. I have also replaced the MAF Sensor.   Also related to the FPG Fuel Hanger – I just realized that I need a Deutsch Crimp Tool to crimp some cables for the FPG Fuel Hanger. Need to purchase additional cables as the kit only included 2, which are for the float. FPG has not responded to my emails so far since purchasing. I thought about taking it to someone and having it done professionally, but I am reluctant since everyone I took it to messed up in some way.
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
