I'm sensing another SAU *Night at the Drive-In* coming on.
For those too young to remember the expedition to Blacktown to see the *Fast and the Furious*, here's some pics
PS: Don't tell Igor what we used to do to his car :)
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
