Im new to skylines, (having come from a wrx, going to the 6cly darkside) but what im wondering is...im looking at getting a r33 gtr. ive seen a couple on diferent car sales web sites with 600hp (i think thats around 400kws)atw. but what i want to know is, would these be lag monsters, that only make the power up higher in the speed range? as i said, having come from a wrx, i love the power off the line that a wrx has, but now i want more and a gtr seems the way to go! i like the look of the r33, so thats the one i want.
1.what sort of power (kws at the wheels) should i be looking for before i start to suffer in the lag area?
2.should i be looking for certain types of aftermarket turbos?
basicaly i want something that is VERY quick off the mark, and VERY quick overall. my wrx had about 160-170kws atw, and it started to bore me!!!!
thanks for any help!!!!
https://www.sau.com.au/forums/topic/73075-power-vs-lag-anyone/
Lag won't be determined by the power figure, you could get a 400rwkw GTR with minimal lag... having said that, a GTR by nature will feel laggy compared to your WRX probably.. have you been in any or driven any yet?
You sound like you want response and power, for that HKS GTSS or 2530 turbos making with forged internals and all the other stuff that goes with it making around 320rwkw i think would be what you're after...
R33 GTR with those goodies your probably looking around the 50k mark give or take.
my wrx came on full boost around 3200-3500rpm, this was after some mods. before the mods it came on around 2900-3200rpm. this was a little laggy (3200-3500) but livable.
what does a modded r33 come on boost at?
the r33 that im looking at (with 417kws atw) do you think it would keep up with a modded rex? i mean, i know the gtr might kill it over the long run, but remembering that the speed limits are fairly low, would it keep up to the rex off the lights up to say.......60-100km/hr?
thanks guys.
thanks guys.
generally speaking I think that a gtr will at least match and quite often be quicker off the line than a similarly modded wrx. personally I have only raced 1 decent sti at the lights, he had a front mount and apparantly he said he had some aftermarket turbo ecu. my car was pretty stock except 1Bar boost so I thought I would get flogged .From a roll we were quite even (I was only marginally quicker), however we had 3 goes off the line and I got him everytime (6500rpm launches), I guess it looked like he had to much lag off the line due to maybe his turbo?, and he then couldnt catch me. anyway I loved my gtr and im still bitter for having to part with it.
like ferni said if your looking for response try to buy something with smaller low mounts such as 2530's or gtss's and you will not be disappointed, but remember that the standard turbos are also good for atleast 250rwkw so thats definately nothing to sneeze at.
you cant use nos on the streets, i think its even illegal just to have the bottle hooked up whilst on the streets.
but the question remains, whould a 22hp shot of nos get rid of lag?
can you get it set up like a dual stage manual boost controller? and have say, 75hp shot on low setting and the full 200hp shot on high?
    • Ok i will get those 310mm. I found one but on a different site. This is the description on those...is it ok? Technical parameters: - Axle: front. - Disc type: ventilated. - Number of holes: 5. - Disc diameter: 310mm. - Total height with center: 54mm. - Thickness (new/min.): 30/28mm. - Designed for brake calipers manufacturer: Sumitomo.
    • You Gregged a whole racetrack!?
    • Look for broken wire or bad connector at the motor. Might not be it, but is worth starting there, as it is easy.
    • Hi everyone, I’m having an issue with my R32 GT-R. Sometimes, when the car goes over a bump or experiences some vibration, the 4WD warning light comes on the dashboard. When I check the code from the control unit in the trunk, it shows Code 19 – ETS Motor. However, everything seems to be working fine — if I turn off the engine and restart the car, the light goes away and everything functions normally. Has anyone experienced this before? Where should I start troubleshooting this issue? Thanks in advance!
    • I'm back from the dyno - again! I went looking for someone who knew LS's and had a roller dyno, to see how it shaped up compared to everything else and confirm the powerband really is peaking where Mr Mamo says it should. TLDR: The dyno result I got this time definitely had the shape of how it feels on the road and finally 'makes sense'. Also we had a bit more time to play with timing on the dyno, it turns out the common practice in LS is to lower the timing around peak torque and restore it to max after. So given a car was on the dyno and mostly dialled in already, it was time for tweaking. Luis at APS is definitely knowledgable when it came to this and had overlays ready to go and was happy to share. If you map out your cylinder airmass you start seeing graphs that look a LOT like the engine's torque curve. The good thing also is if you map out your timing curve when you're avoiding knock... this curve very much looks like the inverse of the airmass curve. The result? Well it's another 10.7kw/14hp kw from where I drove it in at. Pretty much everywhere, too. As to how much this car actually makes in Hub Dyno numbers, American Dyno numbers, or Mainline dyno numbers, I say I don't know and it's gone up ~25kw since I started tinkering lol. It IS interesting how the shorter ratio gears I have aren't scaled right on this dyno - 6840RPM is 199KMH, not 175KMH. I have also seen other printouts here with cars with less mods at much higher "kmh" for their RPM due Commodores having 3.45's or longer (!) rear diff ratios maxing out 4th gear which is the 1:1 gear on the T56. Does this matter? No, not really. The real answer is go to the strip and see what it traps, but: I guess I should have gone last Sunday...
