Hello everbody my name is Adel I am rebuilding my RB26 engine on my GTR R34 and I am looking for the engine tightening torque, can anybody please give the right torque tightening starting from the head studs to the bearings, am going to use 88mm pistons and the rest.
Awaiting for an answer as soon as possible please.
:bs!: :bs!:
Best Regards to all
https://www.sau.com.au/forums/topic/73188-rb26-engine-rebuild/
I assume they are the same for any RB26? I've just rebuilt mine using 88mm pistons as well and can give you the torque settings we used, though mine's an R32.
Tighten to 29 Nm
Tighten to 108 Nm
Then loosen all bolts completely
Tighten all to 29 Nm again
Finally tigten all to somewhere between 103 to 113
Thank you man,,
Am using single turbo HKS T51R-SPL and HKS Cams 272 deg in/out do you have any special tricks or setings to gain mor power? or what will be the best timing set up,
Adel
Tighten to 29 Nm
Tighten to 108 Nm
Not at the moment. It's still sitting on the engine stand. Hopefully drop it in this weekend and tune it during next week. As for now my turbos and cams are still stock. I've done the rebuild first (was sort of forced to, stuffed the last block) and will then add some meaty cams and bigger turbos.
One thing for sure, it will be tuned very much on the safe side at first and then I'll try and clock up some quick kays at low boost to run it in. Will get back to you once I start trying to milk some power. I was running 320rwkw but that was on very high boost. How the standard turbos didn't shit themselves I'll never know.
Hey Matt,,
My mechanic is asking few questions like
1. Can the head Bolts be reused ?
2. Can the Con Rod bolts be reused ? both are in good condition though.
3. How do you start tightening the head bolts? he means do you start from the center bolts then back to fwd or what is the best way, coz again he works with ferraries and its his first time to work with the RB26 enigine.
4. Head bolts torque
5. Main bearings torque
6. Con Rod bearings
7. Cam shaft caps
8. Flywheel torque
Sorry Matt for being a Pain but its imprtant to me.
Thank you
Adel
Yes
Yes
Middle, then fwd, back, fwd, etc till you reach the outer bolts
Sorry, just reread your first question in this thread. Those settings I gave you are for the head bolts.
6. Con Rod bearings
7. Cam shaft caps
8. Flywheel torque
I will post these later today, I don't have them at hand.
mate, do a search on here for "R32 Workshop Manual", there is a full copy posted in english with all torques and tightening orders, everything you need :)
I reused the head bolts but replaced the rod bolts. But unless you are a real tightarse just replace both, better than pulling it all apart again later
That's where I'm getting the settings from, the r32 workshop manual.
I suppose I should have replaced the rod bolts but 'meh', they'll do. It's nothing to do with being a tight arse (hell, I've spent 12 grand on just engine parts not including turbos), it was more to do with couldn't be arsed.
    • ..this is the current state of that port. I appreciate the info help (and the link to the Earls thing @Duncan). Though going by that it seems like 1/4 then BSP'ing it and using a bush may work. I don't know where I'd be remote mounting the pressure sender... to... exactly. I assume the idea here is that any vibration is taken up by the semiflexible/flexible hose itself instead of it leveraging against the block directly. I want to believe a stronger, steel bush/adapter would work, but I don't know if that is engineeringly sound or just wishful thinking given the stupendous implications of a leak/failure in this spot. What are the real world risks of dissimilar metals here? It's a 6061 Aluminum block, and I'm talking brass or steel or SS adapters/things.
    • And if you have to drill the oil block, then just drill it for 1/4" and tap it BSP and get a 1/8 to 1/4 BSP bush. The Nissan sender will go straight in and the bush will suit the newly tapped hole. And it will be real strong, to boot.
    • No it doesn't. It just needs an ezy-out to pull that broken bit of alloy out of the hole and presto chango - it will be back to being a 1/8" hole tapped NPT. as per @MBS206 recco. That would be for making what you had in alloy, in steel. If you wanted to do just that instead of remote mounting like @Duncan and I have been pushing. A steel fitting would be unbreakable (compared to that tragically skinny little alloy adapter). But remote mounting would almost certainly be 10x better. Small engineering shops abound all over the place. A lathe and 10 minutes of time = 2x six packs.
    • Ahh. Well the block damage is a problem, you really need to run a tap or thread chaser through it to see if the threads can be saved, but any chips are likely to be bottom end bound which is bad. Earls seem to have what you need if you want to stick with mounting direct on the block: https://rceperformance.com.au/parts/earls-straight-adapter-1-8-npt-male-to-1-8-bspt-female.html, but as I said above I'd recommend remote mounting the sender
    • I'm not quite understanding or I'm missing steps here, (I appreciate people are trying to inform my brain but I am of the dumb, especially today) - All I want to do is mount the male BSPT of the OEM sender into the system somewhere without it snapping the adapter via vibration. The Nissan sender has a male 1/8 BSPT output. The block has a (very destroyed) 1/8 NPT input. I'm not really sure how a lathe assists with that, and also don't know anybody with a lathe, nor specifically what I would want to buy. I'm not really sure how adding additional adapters creates a better, more leak proof resilient seal here.
