I have a rush pod filter for sale,
come with original box(still with $250 price tag on it!), only used for a very short period..
prefer sydney buyer for pick up, but will post anywhere in australia.
filter comes with R33 adaptor.
NOW $50
https://www.sau.com.au/forums/topic/73260-rush-02-pod-filter-as-new-80/
i personally dont know since i have never had it on the car... but from experience i would say that it would be a louder pod as usually the cotton are quietest, then foam, then metal..
just buy it and find out :rofl::D
yeah no worries ill send it anywhere and yes it has the adaptor fits straight on r33..
About the picture, i done have a digi cam, but i will get a picture of it for you soon, probably by tomorrow.
does anyone know if this sucker is a loud pod??
Unifilter are actually one of the quietest on the market. If you have a BOV which every 2nd bloke does these days anyway you wont here it.
They are a great filter but are prone to heat soak, if you install it use a heat gauard as well and (turbo wrap) to minimise this.
Other than that the only other thing i can say is that becuase its a wet style filter you will ahve to clean your AFM every now and then with some contact cleaner other wise it can cause the car to run poorly.
Good luck with the sale, at that price its a steal ad shouldn't last long :cheers:
gday fellas
i have had to put a q45 afm on my car. im guessing this filter will not fit the afm?
hey mark, i dont think it will fit as the q45 from memory is 10mm bigger, but you work in the building next to mine dont you (centennial plaza) if u do give me a buzz on 0402465128 or pm me and ill bring the filter with me and u can see for yourself.
its cheap for just the filter anyway an adaptor shouldnt be much if it doesnt fit.
    • Maybe also really stiffly sprung track cars. Get the inside wheel up in a corner and all the fun stops. Also me sometimes (rarely) when I have to stand on the brake to convince the diff to drive the wheel that is still on the ground when I'm trying to diagonally get over severe driveway entrance, etc.
    • I feel like I'm missing something. You had an authorised installer come out and install a new alarm. Post install the car doesn't start, and you aren't getting the installer back to fix what they did wrong?
    • So either way it is gearbox out and look what is wrong?  I know about the input shaft bearing. Even before swap/new clutch the it sounded exactly like this: So is that inout shaft bearing or the other was installed backwards?  And can some please tell me the part number for that input shaft bearing? The gearbox is small box from R34 N/A and number is FS5W71C. Thank you
    • I am yet to see anyone ever regret a quaife or helical. ...other than drifting/skidpan duties. I kind of want to upgrade my factory helical with a Quaife (but really it's not ultimately that different, and is a MASSIVE UNDERTAKING), that's how good the hype is about them, that I want to try them 'just to see'
    • D2 and Ksport are essentially the same thing and basically just generic Taiwanese manufacture. Better than ChinaBay crap, but... not top shelf. Öhlins have got to be some of the best dampers around, so likely to be a good option. It's going to get to the point though where I suggest you buy from Oz. We have at least 2x excellent options here. If I were you though, I'd be talking to KW about doing something for the R33. There's bugger all difference between that and the 32. In GTR land, anyway.
