FAT32 - how much power does 2535 make on a RB20? When does it start to spool where on the RPM range do you get 1 bar?
This has always been an impossible question for me to answer since I believe it depends on many factors like amb temp, what gear you're in, what type of boost controller you're using, how your engine is modified etc, etc, etc.
The only way I can answer that is by a general opinion. IMHO I would say that the HKS GT2530 is prol the best turbo for a stock RB20DET. I only swapped up to a GT2535 to because I wanted less mid range punch ( around where the engine starts making it's power ) and more legs above that point ( if that makes any sense ).
Now Mark, does what I said about the wastegate actuator make any sense to you or not ??? If you truely believe that your bleed valve can work on my car I will re-purchase one. :)
I guess a more appropriate qusetion would be.......has anyone installed one of these valves on and RB20DET and with what results ?? Pics of installation would be REALLY helpfull.
  • Replies 1.8k
Posted Images
So what's good ????  ( without the rocket scientist degree ).
HKS EVC 3 or 4 is good. I have a EVC 3 and works really well.
I also have 1 of these boost controllers which is going into my turbo diesel 4x4 so I will see how it goes when i finially get a chance to install it
Mark
Im not saying your product is bad and that the powerup product is better.
All i was saying is that all these products are very close.
We did our own test because we fit and sell these products to the general public.
We just dont sell PowerUp, We also sell turbosmart, GFB & TurboXs.
As for your post on the dual stage boost controller, it all varies on the actuator and how this unit was installed, we have sold many dual stage boost controllers on late model turbo's and never had any issues, the only issue we have had is on the EVO's as there factory wastegates leak at above 15psi.
For a MBC boost controller to work the wastegate should be in good condition and the unit installed right, no matter what brand you use if the above two are not conditioned then it simply wont work. Even a EBC won't work.
See this article
www.autospeed.com/A_1465/cms/article.html
Maybe we approach ZooM to do some test's.
With a bit of luck my controller should turn up tomorrow.
It's replacing a t/smart boost bleed.
So I'll do some back to back testing on saturday, then on sunday I've got a track day so It'll get a bit of a workout. Hoping for quicker boost up.
I run my car at 15psi at present (have done for 5/6 years) and it has always spiked to 17psi.
Hooks
read all the posts and seen that there are a few GTR owners out there with these, just still not 100% sure how to fit it to mine, i was wondering if anyone can tell me where to fit it or send me some pics of it fitted to the RB26DETT engine, ta.
Ok, got it today (thanks Simark)
results tomorrow.
Little more background;
Car is running RB20det ECCS 6 port red rocker cover.
RB25 roller turbo
R33 GTS intercooler (I'm after an R34 GTS I/C for nix, any offers?)
Cat back 2.5" exhaust, standard airbox, O2 rush air filter.
Hooks
(I'm serious about the R34 intercooler)
Late R31 came with 6 port red rocker cover.
It's on!
And it does exactly what its supposed to do.
Boost bleed; max boost 3800rpm/ 3900rpm
New Simark special; max boost 3500/ 3600rpm = fatter torque
NO SPIKE!
also, has a smoother ramp, feels slower but is actually quicker.
I'm very happy so far.
I'll let you know how it goes tomorrow around Wakefield park.
Hooks
Okay, i was playing around with my GTR today attempting to fit the boost controller as i have now got my exhaust fixed yesterday, I plumbed it in in place of what i presume is the standard boost controller, and just wound it down and the intention of backing off as soon as it went above stock boost so i knew that i had it in the right place, but to no avail...is this the correct position for it, do i need to remove that little restrictor in the line or have i got it in the wrong place all together, cheers.
Yuo have got it where in the right place. thats the solanoid you have taken out of the loop. and yes its what was controlling the boost before.
From the photo it looks like it is wound up to like 20psi!!! you need to screw the bolt almost all the way out. so that these are only a bout 3 - 4mm of thread i n the controller.
then test drive it and make sure boost is standard level
then tighten it about 1/4 of a turn and drive it again.
do this untill you have reached your desired boost level :rofl:
If you wind the bolt out all the way and the car still overboosts, you have got the hoses connected around the wrong way on the controller. (i cant tell from the photo) If this is the case just swap the hoses around on the conteoller.
hope that explains it all;)
Or read my posts a few pages aback that say this is not suitable in the stock location on a GTR and you need to re-do all your vacuum plumbing.
Yeah, i'm going to replumb it this week as it doesnt change the boost at all when i have it set even how the photo shows it wound right up...ta.
    • So, I've had my V36 for about a month now and have already copped an "excessive exhaust noise" notification from QLD TMR, reported by someone in my local area. It's a twin as per the original, and can have a bit of a throaty note to it when idling cold 😄 and if I do get up it a bit, it can be noisy, but it did pass a roadworthy inspection before sale, so.... ... but in the interest of being a good neighbour, I do want to quieten it down a bit. Is anyone here running a quiet aftermarket cat-back on their V36 or 370Z? And the big, bold question: does an aftermarket cat-back really make much of a performance difference on these cars?
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
