ah i see, so wats an intelligent individual like yourself doing using it :P
thanks, now i know what to do but, now ima have to check the letter box every ten minutes until it arrives
Edited by brainlessnoob
  • Replies 1.8k
Posted Images
ahh i gave up on emailing him, he didnt seem to reply, odd. I just went and bought 1 from ebay, havent heard back from him, but at least i know he'll have to reply this time :P
Edited by 32thrasher
I should have done the same !
Was meant to be here by the lastest today, and theres the drags tomorrow night :P
only time I get to go out (once in a blue moon) and was hoping to have it for the drags
ah well...
Hi,
I just ordered the Boost Controller and I was wondering if I can use it but still run my standard boost. Will using this boost controller make my turbo spoil quicker even if I still have my turbo running at 7psi?
If it will work like this do I just leave the boost controller fully open?
Thanks
Matt
youll run probably 2pis over stock as a minimum, and yes, the more wound out it is the less itll run. cant have it wound out too much or the ball wont be held in place by spring and it could get messed up. if u want to run stock boost, dont worry with it - the difference between 7psi normally, and 7psi if you could get it with this is not huge. not the best investment if you are wanting to run stock boost
Edited by NewKleer
Blackrb20silvia asked this ages ago but I couldn't see an answer.
How do you connect it for external wastegate setups?
Boost reference ------ boost controller ---------- bottom port on wastegate?
leave top port open?
bought mine friday on bay got on wednesday, after a bit off fiddling with annoying small gaps and annoyingly taught hoses i got it on and wow. I used to hate the way my car had no balls after 5krpm, now i barely notice it drop all the way through to 6200rpm when i shift. Also it spools at only 2000rpm, as compared to the old 2800rpm with the pod and 3000rpm stock standard. It spikes a little bit from .8 bar - .83 bar, .83 bar being 12 psi, so ill just leave it like that. 12 psi (.83 bar) is the recommended boost to run on these engines right?
chris is the wastegate setup your talking about the standard one? because if it is catkicker wrote up a good guide under the heading "installing turbotech boost controller" or something like that
ohh k i only half read your post, youve got a toyota engine or something, i thought you had a black rb20. Gotta start sleeping more
Don't know how that got there. I have toyota 1jz-gte with large single turbo, external wastegate. Use this controller inline with bottom port on wastegate?
Still aint receievd mine yet, Said he sent it but i checked the mail room as i got it delivered to work but not boost controller!
What the!
If he gave you the tracking number, ring up auspost and get them to look it up. If not ask him for it. Mine came in one of those express post envelopes. Check the mailroom blokes pockets to, i work in a mailroom and its funny how easy it is to claim stuff missing, mwaha
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
