fugi: find where your wastegate line is, and just put the controller in that line. don't go running it from different locations than the stock setup.
sorry to be a noob, but i cant find it..
so you saying those lines that i took a picture of arnt used in puttin the BC on??
Is that even my bleed valve??
Plz help..
  • Replies 1.8k
Posted Images
yea i saw that post and i posted a pic of what i thought was the r32 version of it. but i was told that i had to find somethin else. Is the pic i posted not the same thing but in in a 32???
But thanks Munkyb0y.. try to take a look at the pic i posted maby u can explain what it is.
Edited by Fugi
fugi, i am not familiar with the r32 at all, and i dont wanna start guessing.
CALLING R32 OWNERS !!!!
lol
R32 is as simple as it can get.
There's a nipple on the turbo's compressor cover, a hose runs from that to the actuator. Simply shove the bleeder int he middle of that hose.. You can't cut it as its too short; head down and buy a length of hose.
Thanks monkeyboy but ur guessing is probly better than my guessin.
Ohh cubes i didnt want to install a bleed valve i already have one of them. i want to install the turbotech BC.
Dose you instruction still apply??
cauz if it dose that means i will have to take off the heat sheild. The screws on it are stuffed..
and also what do i have to do to my bleed valve?? remove it??
Edited by Fugi
Do you guys tend to leave the stock restrictor in place. I Had mine out and the boost sucked, i could not turn the controller in much to get 10 psi, so teh spring hardly did any work. I migth try it with the restrictor in place.
your talking about that little brass thing in the hose before the BC?
I left mine in, BC seems to work great with it in. I wondered myself if should take it out.
i don't have a restrictor in mine. i put a new bit of hose on there. didn't seem to affect it at all.
fugi- yes cubes instructions still apply. when he is talking about a bleed valve he is talking about a boost controller. doesn't matter what type.
i brought one of these of a member and it's rooted had it on 2 diffrent cars and the boost just shoots up to 15 pound adjusting the spring does bugga all . i think the previous owner put a differnt spring in it for some reason :-(
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
