Time to upgrade to a GTR....
car has...
advan wheels
lowered
bodykit
nismo exhaust
nismo carbon fibre b pillar covers
nismo 300km/h speedo
extreem lightened flywheel and ceramic cushion clutch
cheetah alarm
running gear all stock
never boosted
will trade as part payment for R32GTR if anyone interested
some pics in my gallery, but will post more later
car needs new home please
https://www.sau.com.au/forums/topic/73422-r33-gts-t-adelaide-16k/
please email all info and pics to [email protected]
highly interested
how many kms etc
Teh car has a nismo speedo, so its really hard to tell k's as I dont know the vehicles full history. who can tell when there from japan anyway. but car drives and runs very smoothly. As always its best if you come down and have a look and go for a spin.
did you check out the pics in my gallery?
I'll upload a couple more right now
yeah u got any from the front? only rear pics... adelaides 4hrs away but im highly interested
A full front pic will be added tomorrow. morning about 10 am . stay tuned I'll even get some of the engine bay. It think the front bar is 400R and low enough to be a pain getting up lumpy driveways.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
