  • Replies 330
what da ???? since when did this turn into a whore thread ???
anyways mona whats this about you constantly owning me ?? pfftt..
only on the straights cause you got that bigger turbo :)
twisties and circuit im still faster........so ;)
hmmm battle of the RB 180`s eh ? Id like to see that !!!!!!!!  so whens it happening ?
Hey, we can do a team thing, you take Mona on the corners, ill take her on the straight......with the STOCK car :)
Whoever said anything about my car having 300kw....its only got 150 at the rear :)
well that'll make me twice owned!!!  thats not fair! :D
LOL oh come on, dont be like that....ill BOV you when you go past me hows that.....lol, i know how much you like my "valve" :D
Besides, what are you worried about, you got a 12 second car.....!! Im sure you not scared of a overweight 1.8Tonne taxi and another line which has a smaller turbo then yours ??!!?? :)
hahahaa.. nah! i'm not worried!!!  i don't mind being owned by you too!!!  i'll just be jealous if you did own my ASS!!!!!!! :D
hmmm..... between your and thomas' bov, i'll be in heaven! ;)
haha ok dean which direction is your bov facing ??
mine is directed to the left side of the car...so Ill take the drivers side and you do the passenger side....well do a twin drive by :D
Wait till end of year mona....you too mintie :)
