I couldnt find it posted anywhere else, so I'll ask - whats the rating on the stock amp? Is it powering all 4 speakers or just the back 2? I have hooked up all my speakers using the stock cables without bypassing the amp and it does sound good but a little tinny - could this be because the amp is rated lower than my new deck?
Thanks
https://www.sau.com.au/forums/topic/73866-the-stock-amp/
Thanks
The stock amps are all varied. Some are Alpine but most are Clarion. They are around 25 - 30W X4 i believe (although that would vary too) they aren't that flash and your new HU would have a higher output (generally 50WX4) which is around 23wrms, so run new wires from ya HU to ya speakers and it will sound 100% better. You wont get bass at all out of your speakers as the stock amps dont have any filters and a vairable gain at all. SO its again all got to come from your deck.
Hope this helps :headspin:
https://www.sau.com.au/forums/topic/73866-the-stock-amp/#findComment-1357348
thanks heaps =) I can just bypass the amp right? dont wanna bother with new wires...
Yeah you can bypass it and use the existing speaker cable that you have wit ya new amp, just make sure that you have segragation so you dont get any noise through your speakers. You can yank the old one out if necessary as its just an anker weight anyway, about all its good for :wassup:
https://www.sau.com.au/forums/topic/73866-the-stock-amp/#findComment-1357647
Anyone got pictures or locations of the stock amp?
Also not sure if its answered but.. The amp powers the front speakers ? rear speakers? or both?
Wanna install a amp/sub unit myself but slowly as I want to learn about it.
The stock amp is underneath the rear parcell shelf in the boot. Open the boot up and stick ya head in there and thats where it would be if ya got one.
As for speakers it depends again on the vehicle in question really like the amp. It maybe driving just front or rear or both.
Installing a new amp/sub is pretty easy, just time takes time, common sence and some patience really. Give us the heads up on what you want to do and im sure that you will get plent of help for what you want to do :P
https://www.sau.com.au/forums/topic/73866-the-stock-amp/#findComment-1360141
    • Apologies for the long post, but needed somewhere to lay out the entire timeline of events and actions taken:   I've got an 89 GTR with a R34 RB in it. It's been running great all year, driven probably 500KM in the last month. It's not my daily driver, just a weekend fun car.    Build info: R34 RB26 - HKS 2.7 stroker kit, HKS adjustable cam gears, HKS turbo upgrades, Trust intercooler, R34 factory DENSO 440cc injectors, JUN chipped/tuned R32 ECU. All of this work was performed in Japan back in 2019.    Thursday 10/2/25 - It's a nice day and decided I'll drive it to work, I start it up in the garage and I notice it took a few extra cranks and sounded a bit funny. I figure maybe it was just because it was a pretty chilly morning. I pull it out into the driveway to warm up a bit before leaving. As I leave the driveway, it feels very off and sounds like a misfire. I pull it back in the garage to deal with after work and take the daily to work. I was able to diagnose it as a cylinder 5 misfire with the old spark plug test (unplugging each plug until a sound change with the engine running). I take off the whole ignition system, ignitor, plugs, spark. *Important note, it is still on the R32 ignition system with the separate ignitor system. I test each system with a multi-meter and nothing presents as a smoking gun. I put it all back together and it starts up no issue. I go ahead and order the PRP R35 ignition conversion kit. It should arrive today (10/13/25)   Friday 10/3/25 - Another nice day, car starts up great and drives great all day. Very pleased that everything seems to be OK   Sunday 10/5/25 - Decided I'll take it to play some golf, load up and drive to the course about 25 minutes away. Drives wonderful the whole way there, I pull in the parking lot and the engine completely comes to a stop. I do not recall if it sputtered at all, but just remember all of the sudden the engine was off. I roll it into a parking spot, try to crank it back on and nothing.  It'll crank and crank and not even try to start. End up getting it towed back to my house and push it up into the garage.    Items I have checked: Fuel in the tank Fuel Pump relay Fuel pump fuse  Spark Plugs & gap Coil packs Ignitor    I know the cylinders are getting fuel as the plugs smell like fuel after a start attempt. I tried spraying starter fluid into the manifold and cranking and not even a sputter.    I decided to do the live CAS test (removing the the CAS, ignition on and spinning the CAS stalk to see if the injectors pulse and spark is active). All of the injectors were pulsing and I have spark at the plug. The half-moon end of the CAS did seem very loose, I'm not sure how much play is supposed to be there, but it was more than I expected. There was no in/out play of the shaft, just the tip end that is pinned on had quite a bit of play.    CAS Play video   When I put the CAS back in, I stupidly did not re-time the engine. I know I need to do that tonight, however, I do not think it will start given it seemingly was not the issue. My plan is to do the PRP R35 coil kit and retime the engine at the same time.    I plan on ordering the Haltech Nexus Plug-in ECU once they are available again, but ideally would like to get this sorted before firing the parts cannon at it and potentially adding more variables.    Anything glaring that I am missing here, I'm a bit at a loss?
    • Get it on a dyno. Get something logging Consult. Run it up and find out what is causing it.
    • Looking for a plenum for rb25 de+t neo  Not looking to push much power maybe 300kw at the wheels, is there much difference in flow for Freddy “Greddy style” compared to original Greddy or options like Proflow or Otaku garage?    I won’t be porting the de Neo head for now as I think it’ll be fine 280-300rwkw but appreciate the help and any experiences anyone has between them and any advice. Thanks  Looking at this plenum for now below
    • engine wise almost no mods: stock ecu Greddy front mount intercooler Greddy forward facing intake w R33 TB stock fuel system, stock injectors, rail etc. Kakimoto racing hyper 3 inch exhaust system Apexi intake filter New NGK –R BCPRES (.8 gap) plugs
    • Nice one @Pac - looks like a fair few 1600's there!
