Toofast2furiousperformance Supra is up for sale
Yes, we are going for GTR R34 ^_^
Lists of mods:
~ GT45 1000Hp turbo
~ EMS 8860 Competition computer
~ 6 X 1000cc injectors
~ Stainless Steel SS321 grade manifold
~ 50Mm External wastegate super release
~ Blitz ID3 Boost controller and Speed Map ($1300.00)
~ Malpassi Regulator
~ Pump 800Hp
~ Stainless steel dump pipe
~ Braided high pressure Oil feed and return line
~ 3 /1/2 inc pupe to cat
~ Jivat airbox
~ Screamer Pipe
~ Magic cat converter 50% more hp
~ 2 X Blits Super sound Blow Off Valve
~ 600mmX300MmX76Mm Intercooler
~ NOS nitrous Kit (currently 50Hp)
~ Blitz Turbo Timer
~ Blitz Boost gauge
~ Automatic transmission (Strong gearbox)
Stereo
~ Kicker RS6 component rear speakers
~ Pioneer Component front
~ Kicker 4channel Amplifier 350.4
~ Kicker SOlo Baric 12L7 750Rms
Exterior
~ CARBON Kevlar Maroon color Super light very strong hood
~ Custom Sleeper front bar (deadly sleeper look)
~ Top secret side skirt and rear bar
~ Underbody L.E.D neon light full set
~ Wide body graphic sticker
~ 96+ Headlights and taillights
Interior
~ Grade B vehicle Inspection
~ ALL black leather mint condition no cigarette burn no tearing or spots
~ WOOD grain Dash
~ Electric seat (driver's side)
Rolling Stock
~ 4 piston brake front and back (GZ limited edition only 500-600made)
~ rays engineering 18" silver with brand new tyres 90% thread
Rego
~ October 2005
~ 60K on odometer
Vehicle Inspection accepted (successful transaction we pay for the inspection fee)
Asking price ~ priced to sell
AUD $39000.00
Email us: [email protected] for more car pictures and info
Or call 0416-143-177
Seriously.. get it while you can @ this price.
https://www.sau.com.au/forums/topic/73999-400kw-1994-single-turbo-gz-limited/
    • f**king around with the bro
    • Ludenham   44.2 tops day no issues
    • Then today, I went to visit a man with an r33 hat Peter and Road and Race sorted the alignment. As it is being set up for general track/hillclimbs etc it has a heap of caster (7o), less camber than I am used to (1o front and 2o rear, as the caster looks after that in turns without the braking downsides), 3mm front toe out and 0 toe rear. Will see how that goes and track tyre wear to see if it does need more camber, but adjsustment is also limited with nismo arms and adjustable bushes at only 1 end. It does have a bent inner tie rod on the driver's side front but as it came up within spec I'll just leave that as is. So, that is getting close to my chapter of this story....could of tidy ups then a shakedown in early October before it finds a new home.
    • So, it went to Unigroup for a run in and tune on Friday, everything went (generally) well. In terms of fixes, the engine was good and there were no leaks. It needed plugs (I hadn't checked them because the coil pack cover was on a new engine and I couldn't imagine they weren't new.....but turns out the temporary plugs to just keep it sealed up were in there.....new plugs gapped to 0.8 and it was fine from there. Also, there was a little preload on the clutch slave which caused some slip. I haven't had the box off so I don't know what the clutch looks like; my guess it is brand new and the pedal had not been adjusted....backed that off a bit and it held fine. Last thing will have Dose crying....the idle especially when cold is a bit difficult between the cams, forward plenum, atmo blow off valve and an 80s air management system. It is fine when hot but a little uneven when cold, will see if I can sort or at least improve that one cold morning. Other than that, tuning went fine. It made 245 but was pulled back to 227 which 2 opportunities to improve in future. 1. The factory CAS is not great and was jumping around at high RPM, so Mark took 2 degrees out up top (that is why it stops making power and lost 20kw). Very safe this way and the extra power is available but will require a more modern ECU and better cam (or even better crank) sensor 2. The 2871 in factory housings is very big for a low mount, and the internal wastegate is too small, so it was creeping from mid range all the way to redline....the duty cycle on the boost controller is turned down a little for safety. That is much harder to fix, it would need a large external gate and that would require a whole bunch of other changes, so it will go as it is for now. It feels nice and healthy and safe, so should be good for about a billion laps like this.
    • what sort of caliper are they? If they are a slider and you gave everything a good clean, you might need to regrease the pins. My guess though is they will come good after some abuse as suggested above
