Z31 300zx. 3.0 litre non turbo VG30E single cam. Automatic. ~160,000 kms. Engine a tad noisy but only broken down once with a snapped belt, but fine after that.
Body is light blue and average. Targa top has tiny leak from one side.
Interior is cushy and in decent nick, most electronics still work fine. Comes with sound system, the highlights of which are two 12inch subs in mirrored box with amp, dunno what brand but nothing expensive.
Has basic immobiliser too.
The car is out of rego and requires blue slip. When we purchased it it had just been blue slipped, and I think I have the paperwork to show this which proves it stands a great chance of passing again. Needs some decent rear tyres at least though.
As you can see there is no panel damage, just the paint is not that great.
Battery is dead, but car has keyless entry when the battery is charged. Rear speakers are Sony 6x9s, amp is 2 channel Boss audio, subs I'm not sure but there is only two, box is mirrored.
Car can be test driven in my street with use of the battery from my other car.
Located in Blue Mountains, Sydney. 40mins west of Penrith.
Please PM to enquire. Ideal project car to drop an RB into.
Michael
https://www.sau.com.au/forums/topic/74073-z31-300zx-600/
  • 3 weeks later...
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
