Hey,
Finally got my engine out last sunday, now all thats left is to strip the rest of the engine bay down.
Im planning on giving the bay and engine a real good clean and respray.
The back end of the box fell on my hand, but dont worry! the gear box is fine.
anyone knwo where i can get some real good undercoat and paint that i can use with a aircompressor and spraygun? i dont wanna use crappy paint cans.
steve
https://www.sau.com.au/forums/topic/74597-spray-painting-engine-and-bay/
just be careful with this weather though as you will need to make sure that were you are paint is nice and warm and the surface is warm at about 21 degrees otherwise when you paint the paint will be dull and will dry that way and no amount of buffing will fix it - also if you are painting with a red paint (including burgandy) don't put a clear coat over it as it will be easier to buff up faded red paint and bring it back to life rather than trying to buff the faded colour if it has a clear coat as all you will be doing is buffing clear(hope that made sense)
Your tempretures, surface, room and paint temp is very important
thanks for the info, the engine bay is black, and i wanna keep it black, cause i want to paint the enngine blue, so i think itll stand out more.
i kinda figured that this wasnt too good weather for painting, but ill be doing it in my garage and ive got 4 heat lamps that i was thinking about using.
so 2pak paint it is then!
steve
yeah 2 pak is great paint to use and the heat lamps will work a treat if you come up after the first couple of coats with small burst air bubbles ( thats the best way of explaining it ) give it a very gentle rub back with 1200 and 1600 grit paper this will just smooth off any minor rough bits without doing damage... make sure the surfaces that you are painting are clean and after you have cleaned it clean it again sometimes when cleaning engine parts it pays to use sandpaper or a kitchen scrub pad as this will help get anything out of the metal parts use prepsol for your final rinsing of grim and dust out of there
preparation is everything and is the hardest bit.... the painting bit is easy
well ive almost finshed stripping down the engine bay, ive taken out almost everything, but i dont think ill be able to take the brake booster out (too much trouble) so ill try to paint around it.
ive got a 20liter barrel of degraser, and degreaser sprayer thing for the air compressor so ill definetly give her a good clean, plus i sand down any rough bit, and finish it off with some prepsol.
ill also try to do the painting on the warm day, my shed gets quite warm on a sunny day so hopefully itll turn out nice.
ill be using the 2pac paint (black), but would it look good if i used 2pac clear coat over the top of it??
thanx for the info fellas.
steve
steve
I personally would deffinately be using a couple of clear coats as that will give the black paint some depth in colour and will be so much easir to keep looking nice as the black can look quite flat dull and boring and could look like you have only done half the job, if you are doing engine parts in chrome or adding some extra bling then the glossy black will just make it look so special... but hey thats me I love shiney things
Just remember to do before and after shots
good point, as im bound to scratch the bay while putting the engine in (no matter how many blankets i use!)
ill see what it looks like when is drys, then ill see if i need to clear coat it or not.
one more question, does 2pac need any special type of undercoat?
thanks again
steve
well this is what I would do it may seem like over kill but that is me after you have degreased it and cleaned everything use a primer putty and spray the bay with this it will fill in any small chips and scratches then give it a light sand this you will probably will have to do by hand when you are happy with the surface after having given it another clean with the presol then you you will be ready to use the black 2 pak if not glossing then get some 1600grit paper and give it a very gentle rub over to remove any dust particles that may of contaminated the surface go careful here it won't damage the surface if you are using a swirl motion then get a good cut polish to give the car a nice finish but it is recommended not to do this for a couple of days even weeks to do this so that the paint is totally dry and has set
If you are tossing up between polishing the metal bits and painting blue on the engine, you can sort of do both. There is a product that is almost like a candy finish, its a coloured chrome type finish. Blue chrome engine - bling baby yeah:p
Oh, and for fitting engine, if its being done at a workshop, easiest way I have seen it done on GTR is to drop the whole front cradle, with engine in place on the cradle, just lower the car into place. Minimal chance of chips/scratches on the nice new paintwork and it really is alot simpler than going in from the top.
G/L cant wait to see the pics :)
As Chrsitine said, it's a good idea to use a primer putty (of high build primer as we call them here!) to fill any imperfections. Reason being is that the gloss finish will accentuate an imperfections that are there! Do several coats of highbuild so that you can fill chips and smooth off high spots.
The 2pac should go off really hard pretty quick (like well within 24 hours if warm enough). You also SHOULDN'T need to use any wet and dry paper or rubbing compound to get a perfect finish, provided your pre-spraying prep is done properly. When you've sprayed the 2pac, if you do find any imperfections then deal with them the same way you would with imperfections in a clearcoat. It should be ok to do this after 24 hours. what you mustn't do is apply any wax to it within like a month as the chemical in the wax can penetrate the finish.
    • Nice, thanks for sharing your progress....that's a pretty long list you are putting into it!
    • Decided to upgrade my pressurised plastic coolant expansion tank for a fancy pants alloy version The OEM versions can get brittle, even the new plastic one I got when I first got the car is a starting to show signs of "stress" I wasn't cheap, but it is basically unbreakable
    • Morning all, I have an RB25DET Neo that's in need of a rebuild. Will need new pistons etc due to detonation damage. Would anyone be able to recommend a shop in Southeast Queensland who I could bring my long motor to for a rebuild? Just want someone who knows RBs and whos built a bunch of them before. TLDR - recommended engine shops for RB rebuild.
    • Gday Thought it was about time I started a build thread! As expected this project has snowballed into a huge financial liability, but unless you’re strong willed and responsible, it’s not a surprise. Background -  My first turbo car was an R32 GTS-4, got my full license and then totalled my Au Falcon a week later, so while trying to sell my RMZ450 dirtbike to buy another car a bloke offered to swap the R32 which at the time I felt like I was ripped off but looking back and seeing prices of those now ($40kish) it was a good deal, I didn’t know enough about these cars to appreciate what I had so sold it before the RB20 blew up. Between here and there, out of 12 cars I’ve owned the note worthy ones are a V8 Lexus SC400 (soarer), a couple of XR6 Turbos and my beloved S15 which I had for about 3 years, picked it up for $12500, repairable write off but she was fine, gun metal grey/pewter and bone stock/unmolested until I got my hands on it. Ended up spending about the value of the car and 280kw, 2 demerit points by the time I got defected and sold it for $14500 (also $40kish in today’s market, rip) Fast forward to the present day, I’m in a much better position financially and daily an MQ Triton (great cars, pipe down Ranger Bois), I cruised marketplace and car sales for a few months looking for another R32, the best deal I could find was an absolute rust bucket half finished project for $12000, until this R33 popped up in Port Macquarie for $18k - unregistered and barely running but decent shape, kept an eye on it for a few weeks and the price steadily dropped, $16k then $15k then $14k, that was the point where I was like shit someone’s gonna snatch this up! It was owned by a young bloke who had big plans but him and his missus just had a baby so smartest move financially for them but big gain for me. So 2 days later I’m towing a car trailer to pick this thing up. Roughly 2 weeks and $3500 later I’m cruising around Newcastle in my beat up R33 all smiles and dose noises! It only needed some basic shit to get it going, coil packs and air flow meter, electrical stuff and all fluids changed, 158k kms and running pretty good, nice smooth engine after oil and coolant flush - when I say coolant I mean it had been filled up with tap water, every gallery and heater element was filled with rust, 8-9 flushes later and still had brown liquid coming out but she’ll be right. The car was painted R34 Bayside Blue at some point but whether it was a cheap job or just not looked after is anyone’s guess, clear coat flaking like sausage roll.  Was rethinking my choices and contemplating life, had it up for sale for $22k - still cheaper than any registered R33 but got little interest, next minute I had an opportunity at work - 6 months overseas for good money, so that was a no brainer, fast forward again and here we are with a 50% finished project. Current Mods - 200ish KW according to butt dyno Was tuned with Apexi PowerFC EBC (old school Greddy Profec)  Stock turbo (more shaft play than a Tinder date gone right) 3inch turbo back Varex muffler  Aftermarket injectors of mystery size, Power FC showed 36% duty cycle at full boost so not behd good size Someone had good intentions but stuck with the stock R33 MAF so we had misfires at 6000rpm due to the MAF hitting 5.2V So far I’ve redone the entire interior with carpet form Car Mats Direct, new Seats and steering wheel from Autotechnica, also sound system by Autobarn (mainly Kicker) Also MCA pro comfort coil overs - Hands down best purchase yet, worlds of improvement over the tired 30yrold shocks Goals - 450kw/600hp on flex tune New paint job - Midnight Purple 2 Engine is at the shop getting rebuilt with forged rods a pistons, new valves and springs, ATI Harmonic balancer, Aeroflow 7.5L sump, rear head drain and oil restrictors as per oil control thread* and cam covers modded for larger breathers, other stuff I can’t recall of the top of my head Parts purchased and to be installed once the engine is done -  Engine loom from Wiring Specialties including these options: Haltech Nexus S3 R35 Coil pack conversion  PRP Dual Trigger kit Fan controller  Other Parts -  262 Kelford Cams Turbo - Hypergear ATR43SS3-ProS with T51R mod (whistly boi) 6 boost manifold (high mount) 50mm Turbosmart Pro gate (plumbed back for legal reasons) HKS Super Turbo Exhaust with High Flow Cat Custom 3.5inch dump and front pipe 1500cc Bosch injectors  Fuel Pump walbro 525 Haltech MAP and IAT sensors Haltech Flex Sensor Fenix Radiator with dual thermo fans LS1 Alternator Kit Oil Filter Relocation from EFI solutions and Cooling pro oil cooler Many other things sitting in my garage waiting for that engine to come back. Progress pics to follow -
    • Losses have to be less with DC coupling. Provided the battery inverter has decent MPP tracking ability - which really shouldn't be a problem. It's not 2005 any more.
