Yeah, I reckon its was some synthetic fluid that started to make mine leak
I have used the Castrol stuff in the red bottle this time, just by pure chance :P
Its the blokes down at ACBS that warned me away from Synthetic fluid. :P
I couldn't believe my chances though, just pick the master cyl up and mine completely pops, I drove home rev matching, switching off at traffic lights, in to first and crank the key. lol
I topped my old master cylinder up before my last Mallala day with synthetic/silicone fluid I was using in my brakes. A week later the seal started to leak. It was always a constant leak though, so I just kept topping it up with the Castrol stuff.
either way its fixed now, and has a resivior full of Castrol fluid!
Good effort to get home with no clutch. Poor ol' RB20 'box!
I asked the guy about my pedal bleeding off slowly, and he reckons it has to be the master cylinder, not the slave.
The slave will only leak fluid, or suck in air. Good way to tell which is stuffed (master or slave) is to block off the line and press the pedal. If it bleeds off its the master :P
He rekons 1 in 50 or so come brand new that are stuffed, so be aware, you can get a dud newie....
You had a dud newy did you not?
I learnt how to drive with no clutch in my first car. The TE Cortina's used to have a surclip to adjust the clutch cable, the damn things would always flick off leaving no clutch. :rofl:
Your clutch was bleeding off like mine.
Its farked, I'm telling you now.
I held my foot slightly on your clutch pedal and it went half way to the floor. :rofl:
Exactly what mine WAS doing.. Now it goes straight to the floor and makes nice squishy sounds.
Having a clutch that isn't bled correctly will cause you to crunch gears and not dissengage the clutch completely.
Clutch master done. :P
I didn't have time to fiddle with the pedal box today as I buggered around removing the little silly box that locate between the master and the slave cylinder.
I simply straightened the end section of the old metal piping then rebent it so that it mated up with the rubber hose that then runs to the slave cylinder.
The clutch seriously feels so much better now. Seriously I tell you. :D
I swear it feels lighter, more springy and much more progressive. Previously it was very bitey now it is much nicer to drive.
Ignore the rust mark on the floor pan. Thats an old heater that went pop under the inlet manifold. The camera really shows it up as orange. I should clean it up really.
  • 1 month later...
The forum change over broke a lot of links, using the WHITE PAGES would have got it for you, but here's the detials anyway:
ALL CLUTCH & BRAKE SERVICE PTY LTD
3 Pinn St St Marys 5042 (08) 8277 8122
Email [email protected]
Internet www.allclutchandbrake.com.au
Edited by Oosh
    • The attached document is fine. I just downloaded & opened it.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
