Are they the twin piston type?
I think the guy said that they are the same as the Z32 TT.
Anyway, check this thread out, there is a pic there.. my brakes look the same..
http://forums.skylinesaustralia.com/showth...s=&threadid=705
https://www.sau.com.au/forums/topic/7556-racebrakes-rb74s/#findComment-110752
The reason I ask about the discs, is because they may have some grooves in them in which case the pads will also have these grooves which means when I put them on my car, the grooves will groove my machined discs, if that makes sense. No thats a fair price, I just don't know that I want squeeky brakes that might root my discs. Let me have a think about it. where abouts in melbourne are you?
https://www.sau.com.au/forums/topic/7556-racebrakes-rb74s/#findComment-110792
  • 3 weeks later...
Well thay are for sale again....
I had my discs machined last week, and the pad surface has been rubbed back so that they are flat...
I haven't driven the car much at all in the past 2 weeks, maybe 3 times a week, so they are still almost new.
Reason for sale is the same: I dont like the noise...
$70 this time...
In case ur wondering, they will fit R32, R33, s14, z32 four pot calipers....
Perfect if u want some pads for the track.
pm me,
prefer melb buyers still, but if u really want them interstate, then u can pay cod...
Zahos
https://www.sau.com.au/forums/topic/7556-racebrakes-rb74s/#findComment-119968
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
