I've got two Greddy gauges, Fuel Pressure and Water Temp (both with the electronic module that does memory and warning), 3 omori gauges in the center console under the stereo, and a Greddy Boost Guage above the steering wheel... the other day all the lights worked fine, and when i turned the park lights on the gauges would light up. But now none of them do. The dash lights still work though. It only happened after i had the clutch changed, and i rang the guys to see if they had changed anything and they said, nothing but the clutch. So i spent half the day today checking the wiring with the multimeter... power is getting all the way to the back of the gauges and the globes are fine. Could there be something wrong with the grounding? The gauges actually work so i assume the grounds are fine, but i'm not sure if there is a different ground for the lights. It's driving me up the wall... if it was one gauge light that went then i'd think it's either globe or the connection to it. But the globe is fine and it's getting power, and the thing is, all the external gauge lights have stopped working. I've checked the fuses too... (unless there is a fuse in the power line somewhere, but i've checked that they are getting power all the way to the back of the gauge)
It's got me stumped! Any suggestions are very welcome
Thanks
Andrew
https://www.sau.com.au/forums/topic/7595-backlight-on-gauges-not-working-ideas/
    • The oil pressure sensor for logging, does it happen to be the one that was slowly breaking out of the oil block? If it is,I would be ignoring your logs. You had a leak at the sensor which would mean it can't read accurately. It's a small hole at the sensor, and you had a small hole just before it, meaning you could have lost significant pressure reading.   As for brakes, if it's just fluid getting old, you won't necessarily end up with air sitting in the line. Bleed a shit tonne of fluid through so you effectively replace it and go again. Oh and, pay close attention to the pressure gauge while on track!
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
    • I take it that the knock retard is from bearings tapping a little tune? Thicker oil is a fragile bandaid. You need a much bigger oil cooler and probably the bigger pump being discussed.
