Hey fellow Cefiro owners,
I am picking up my cefiro this Saturday and need to get some facts clarified so i can keep the boys in blue happy, and also get some advise......any feedback / answers would be greatly appreciated!!!!! :uh-huh:
1. Roll Cages - The car has a cage in it which runs thru the front to the back. Now as far as i can gather and researched, the rules with a cage is that -
* No cage frontwards of the most rear position of the drivers seat?
* Rear seats, belt stalks, 'everything' has to be removed
* Has to be rego'd as a 2 door coupe
* Cage has to be engineered
Now if the engineering part is correct, does anyone know where i can take it to get this done (in syd) and what costs???
2. Rolling Of the Guards - As i briefly mentioned in another thread, the front tyres are rubbing like biatches on the guards, whenever i turn, brake, bumps, anything. It currently has 205/60/15's all around, aswell i think the rims have to have some form of spacers on them as the rims sit out VERY wide, thus why i think they are scraping...ddduurrrrr.
Anyways trying to locate a place to roll the guards......i have advised of 7 Day Tyres in Granville, but was wondering if anyone knew anyone who could do it more around my area. Chatswood area.
Also has anyone had this done to their ceffie? Wont it cause the paint to stress and 'crack'??? Or do they do it slowly enuff that its all good????
3. Lastly but not least....... things u recommend to get done once u pickup the car....IE. change oil, oil filter, etc.........
Sorry dudes about the questions......just a newbie to the import stuff and just need to make sure everything goes okay!!!!
Thanks in advance for all the feedback!!!! :rant:
Ando
https://www.sau.com.au/forums/topic/76143-a-cefiro-few-questions-help-please/
I use to run a 185/60/15 tyre on the front (fresh from Japan)... never scraped ever!!! - well not much :rant:
... as soon as i went to a 205/60/15 I couldnt even lower the car down off the jack haha. Pics for your amusement.
JK
My advice is to get it engineered and rego'ed properly as you're going to drive it. There's really no point in being dodgy about it, doing one thing to pass it off then doing another in actuality.
I'll talk to you about engineering. Can't help about the tyres but when you get it you should do the following:
engine oil
coolant
brake fluid
clutch fluid
gearbox oil
diff oil
tyre pressure
Not in order - and stuff like gearbox and diff oil are optional or atleast something you should think about within the first year of ownership, unlike the engine which I would change very first thing.
Thanks for the feedback so far guys!!! I am sticking with CC's attitude that i want to register it as i want it to be. So i am having it rego'd as a 2 door coupe, etc. As for the guards i may look at getting some 185's for the fronts and see if it does the trick!!
CC- Mate i'll be on the phone to u as soon as i get the ceffie in my hands!!! :cheers:
get it rolled like mine :cheers: i'll put up some pics....i've got some 17x9.5 rims +20 offset 225/45/17 semi slicks and i've still got room. guard rollling ar 7day tyres is cheap, that's why i suggested it. 2 guards for $50. they heat up the paint with a heat gun to avoid the cracking.
Sky80 - Mate a ppreciate the pointer.....thats why i mentioned them as u recommended them! What sort of timeframe will it take em to do all 4 guards?? Is it a in-out job couple of hours or am i gonna have book it in?
P.S. Just called em and they said $35 per guard. Did they give u mates rates or something sky80???? :cheers: They said they could do all 4 in about an hour...that sound about right to you?
shouldnt take long. 15min per guard is pretty long, they did a friend's skyline in about 15min for both rears. and they only charged $50. its not really mates rates, cos it's not like i know any of their names...just go in and pretent you're a fully hecktic cuzz (even though im asian) and bargin with him. a mate got a huge deal off them last week cos he bargined with the guy for like an hour. saying how we been going there for like 3 years (which we all have) good luch mate :cheers:
I use to run a 185/60/15 tyre on the front (fresh from Japan)... never scraped ever!!! - well not much ;)
JK
I run 235 fronts, they dont scrape? :dunno:
Couple of things, I would also do the feul filter,
In regards to the cage, some places just wont touch it, there are a couple of requirments, such as have cant stick out more than 10 or 15 cm past dash or under it if you get what I mean. Otherwise have a look at RTA website. they will have to engineer it when you get compliance so knock the two birds off with the one stone, and ask around.
Sky80 - Lol thanks for the piccys.....mate those guards look great.....is that the end result of having em rolled at 7 Day Tyres??? If so looks like they do a good job.......mine should be sweet once i get that done! Will double check once i pick up my Cefiro tomorrow but i think i got some kinda offset + maybe a 20mm spacer....not sure thou....
CC - PM SENT :)
    • Yes the gear for the R33/34 is different, it is red and has a different number of teeth. My part didn't come with that gear though, so I don't know how many teeth are on the red one. You'd have to reuse the 260RS/R33 gear, as long as it's not destroyed.   Haha, as unfortunate as that might be it was working fine for about the first 1500km I've had the car for now.
    • Update all   thanks to the workshop manual, it lead me back to checking fuses as mentioned central locking and door open lights worked when acc was switched on. diagram attached shows two points of power 1. ACC and 2.  Batt with the later being fused (#28) I did check the fuses using a multimeter but I must have stuffed that up also. Went back and checked the batt fuse in interior fuse box and you wouldn’t believe it… a blown fuse. replaced fuse and everything is now working as it should including the climate control   thank you all with your positive insight and knowledge.
    • Where is the warning "That this thread is super old"   I just went into a 5 year old thread, went to do a reply, and couldn't see anywhere obvious a warning of it being super old
    • Duncan is correct. Pitwork (and Toyota's own cheap brand "Drive Joy") were primarily created as brands to sell other manufacturers car parts. It would be weird if Nissan sold parts for Toyota vehicles with a Nissan logo on it, so they created Pitwork to sell parts for other brans Toyota, Honda etc. They are not the same as Nissan genuine parts, although they *do* meet Nissan's standards for replacement parts. They aren't supposed to be a substitute for genuine parts, but a cheaper alternative that is better than Ebay fake parts from you-know-where.
    • Thanks GTSBoy, much easier to work with it now it's free!
