  • Replies 125
Originally posted by VISHES
i think the conversation between helen and goog went something like this:
Helen: my front is bigger than yours!!
Goog: no way, mine is bigger..i can't even see urs....let me seee it from the bottom up!!!!
HAHahhahaa
Helen: nah googz, your kidding yourself, yours is only this big!
VISHES wants to be a sleeper now!! hehehhe
nah i've still got them...just wanted this look for now..plus the wing increases the drag coefficient..and the other rims had shitty tyres
hehehe this coming from a guy who didn't care his undertray wasn't secured properly :D
Have you fixed it yet? You've probably got 1/2 left now from all the rubbing on the road :eek:
hehehee...u can PM me :D lolz...although i can make an educated guess!!!!
Whats the guess?? what happened??? didn't know Franky was that kinda guy.... lures the girls from the group and takes advantage... no good la
You have to chase em... esp if they in a SS commo.... heheh
