PRICE DROP 24,000 NEGOTIABLE
R33 GTSt M Spec
108,200km approx (bought in april 2003 with 88,000kms)
Mods (and i'll probably leave a few things out as theres so many)
APEXi PowerFC management with handheld controller
Turbosmart E-Boost electronic boost controller
PIVOT super baby turbo timer - stealth setup in ashtray
Aftermarket hybrid turbo (model is unknown but is larger and a lot better than standard turbo, boost comes on hard early and has a great meaty power curve all through the rev range) with reinforced wastegate actuator by Unique Autosports to hold boost and bring it on better
223rwkw
GTR front mount intercooler
Z32 air flow meter for more agressive tuning
SPLITFIRE 80mm boost gauge on drivers side A-Pillar
HKS exhaust cam gear
TRUST/Greddy oil catch can
New 6 button clutch fitted two weeks ago
GTR fuel pump and 550cc injectors (claimed when i bought the car from previous owner- have never pulled them out to check but i feel thats right as the fuel system would have maxed out with the standard items
3 inch exhaust off the turbo to high flow CATCO 3 inch catalitic converter into HKS Super Drager cat back exhaust system
Pod air filter enclosed in custom made insulated cold air box with induction piping from front bumper
bendix ultimate brake pads all round
Autowatch 3 point immobilser with digital siren alarm system
Sony Xplod Cd player
altec amp with 10" sub in box (for wank factor) pretty much unused in the garage
Carbon fibre gear knob
custom R33 leather handbrake and gearstick boots by Jay (SAU)
fire extinguisher set up in back
wheels are Speedy Holotype R rims 17inch
tyres about 6 months old 235,45,17's Hankook Ventus Sports
electric windows
airbag steering wheel (not available on series 1's)
REDLINE lightweight shockproof gearbox oil
always run with PENZOIL Turbo oil 10w-30
Genuine Nissan floor mats
100,000 Major service with new timing belt replaced at appox 93,000kms
rego till february next year (license plate ECR33M model ECR 33 M Spec)
1995 model, built 1994 (its a series 1.5) best bits of series 1 with series 2 engine and bodykit and a few other bits and pieces from the series 2
as you can see there has been thousands spent on this car and has been regularly serviced and lovingly taken care of
extermely quality interior (minus the few marks on steering wheel) (bloody japanese men picking at them)
25Kono
  • Replies 49
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
