I'm currently selling my Ceffy for around 13.8k negotiable with rego up to Nov 05.. usual features such as electric everything etc :cheers: There are a few dents on the body of the car, however will be fixed up before sale. Or I could get a quote and drop that from the price, which ever works for you. Bear in mind that i'm in the middle of Uni exams so I won't be free this coming week.
A31 Cefiro
Engine: RB20DET auto
KMs: 102k
Interior Modifications:
Recaro SR3s both sides
Sony Xplod Headunit
Carrozzeria speakers
Exterior Modifications:
East Bear Drift Mirrors (with electric adjustment)
18x8 (f) & 18x9 ® Work Ryver Touring
'93 Spec Grille
Clear Indicators
'93 Spec Tail-lights
Performance Modifications:
HKS GT2510
3" stainless steel dump
Chipped ROM
3" Cat Back w/DTM rear can
RG JTC N1 Coilovers
RG Brake Pads
M's air filter
Turbosmart BOV
Momo steering
Straight swaps welcome
No Plates
email : [email protected]
https://www.sau.com.au/forums/topic/76528-nissan-cefiro-138k/
    • ..this is the current state of that port. I appreciate the info help (and the link to the Earls thing @Duncan). Though going by that it seems like 1/4 then BSP'ing it and using a bush may work. I don't know where I'd be remote mounting the pressure sender... to... exactly. I assume the idea here is that any vibration is taken up by the semiflexible/flexible hose itself instead of it leveraging against the block directly. I want to believe a stronger, steel bush/adapter would work, but I don't know if that is engineeringly sound or just wishful thinking given the stupendous implications of a leak/failure in this spot. What are the real world risks of dissimilar metals here? It's a 6061 Aluminum block, and I'm talking brass or steel or SS adapters/things.
    • And if you have to drill the oil block, then just drill it for 1/4" and tap it BSP and get a 1/8 to 1/4 BSP bush. The Nissan sender will go straight in and the bush will suit the newly tapped hole. And it will be real strong, to boot.
    • No it doesn't. It just needs an ezy-out to pull that broken bit of alloy out of the hole and presto chango - it will be back to being a 1/8" hole tapped NPT. as per @MBS206 recco. That would be for making what you had in alloy, in steel. If you wanted to do just that instead of remote mounting like @Duncan and I have been pushing. A steel fitting would be unbreakable (compared to that tragically skinny little alloy adapter). But remote mounting would almost certainly be 10x better. Small engineering shops abound all over the place. A lathe and 10 minutes of time = 2x six packs.
    • Ahh. Well the block damage is a problem, you really need to run a tap or thread chaser through it to see if the threads can be saved, but any chips are likely to be bottom end bound which is bad. Earls seem to have what you need if you want to stick with mounting direct on the block: https://rceperformance.com.au/parts/earls-straight-adapter-1-8-npt-male-to-1-8-bspt-female.html, but as I said above I'd recommend remote mounting the sender
    • I'm not quite understanding or I'm missing steps here, (I appreciate people are trying to inform my brain but I am of the dumb, especially today) - All I want to do is mount the male BSPT of the OEM sender into the system somewhere without it snapping the adapter via vibration. The Nissan sender has a male 1/8 BSPT output. The block has a (very destroyed) 1/8 NPT input. I'm not really sure how a lathe assists with that, and also don't know anybody with a lathe, nor specifically what I would want to buy. I'm not really sure how adding additional adapters creates a better, more leak proof resilient seal here.
