for sale is a 9 inch TFT/LCD widescreen dash mounted monitor the screen has an inbuilt tv tuner so you can tune it to tv channels while you drive..comes with all cables, boxes, warranties, remote. Also a Slimline Playstation 2 with box and 1 controller. The PS2 is mounted beautifully into my glovebox and can be easily removed without leaving marks on the console..the screen is mounted on the passenger side dash...also have very small lightweight power inverter for the PS2...comes with everything needed to run...
After $650 ONO
PM me if interested i live in brisbane if anyone wants a look
https://www.sau.com.au/forums/topic/76687-fs-9-inch-tft-with-slimline-ps2/
    • Hopefully you can just unbolt them, thank them for their service, then bin them and not replace them Apparently the sensors like to set them off with only minor impacts at low speed It looks like they do a delete kit for some of these, but, it is costly
    • I hope it's actually possible. This is a write off in insurance world.
    • Yup. 2-way with shallow ramp angles. Still works.
    • That was the first session so not a lot to take from the day. It was low 20s ambient and the coolant had got to 110 (and obviously had some pressure!) so that still needs to be addressed. I haven't downloaded the data yet but will. I had refilled the auto trans with Redline DT6 because it claimed the best viscosity I could find at 100o. It wasn't really long enough to get a good feel for that; while the trans got to 100o in the session it still wasn't shifting crisply as I hoped. I think I'll try a few more sessions before judging. No steering motor overheat but I'd hope not in only 1 session! But finally the suspension; it was night and day over the standard stuff and the car was a couple of seconds quicker on the same crappy tyres, which is a huge difference. I'll stick with that and get some sway bars and a mechanical diff sorted too and see how that all goes together
    • I guess it’s partially a compromise of how my car is used, wanting to be able to switch from drift to grip with track side on-car adjustment. Also partially with the way the knuckles are set there is more static camber but less dynamic camber gain.
