Even Bigger BHP UK GTR Owner Joins.
  • Replies 52
Boostmiester,
Yeh,my R33 has been on a couple of videos over the past two/three years.
Munro,
This year 2002 has seen a big start to Skyline Drag Racing in the UK with road legal cars doing great times,the quickest of the year belonging to "rocket Ronnies" R33 .....10.78sec.....,I`ve done an 11.30 in my R33.There were several more cars in the 11`s and to think these cars were driven to the Drag Strip,did their Times and were driven home,Skylines are amazing!
We are also into Top Speed runs were 209mph was this years quickest time and 0-60mph times got down to 3.2 seconds.
I have purchased with my good mate,Guy,a Pro-Drag R32 from Sunyou Garage in Japan which we will run next year but has already won many Events in Japan with times in the 9`s.This car we have named "Project X" and its road legal too!
2003 will see times tumbling,all we need now is some good weather,help.
Happy New Year,
Henry
Awesome.Fast Skylines are so cool.
I also have an R33 GTR.So far it has done a 10.6 @ 137mph.
Wouldn't exactly call it "street legal" though.I am currently looking
at my fuel system.Have 6 x 1000cc injectors, but am thinking of running a 2nd rail with 550cc as well.I couldn't tell from your photo
if you have 2 rails or not?
I have just received a new Holinger 6speed & hopefully the car will be ready to race in mid January.I have never pulled nines before, so hopefully, with this new combination we can crack through the barrier into single digit territory.
Another Adelaide fella has driven to the track & pulled 9.74 recently.I've been in it (an R32 GTR) on the street & it's very streetable.You are right - they are amazing cars.
Hmmm, weather.We have the opposite problem.Last couple of times at the track it was nearly 40 degrees!Great for traction but not too good for turbo cars(or the drivers)
Oh well, at least the nights are nice & warm.Night racing would be good!
Cheers,
Munro.
Yes,Project X has twin rails,a set of 550s & a set of 720s.We have the Holinger 6 speed sequential too.
I think a lot of us in the UK need to learn as much as possible about launching our GTR`s, as I`ve said before, we are new to Drag Racing.
Henry.
At the moment I am using HKS 2835R turbos.
They are smaller than yours & may be replaced later once the rest of the car is fully sorted out.
I dont have a handbrake.Instead I use a line locker in the back brake line with a button on the steering wheel.The plan is to take
up the driveline slack with the back brakes locked on & release them on the launch.Haven't mastered it yet & am breaking heaps of shit!!!
Eventually I would like to run 3240 turbos, but I'll wait & see.
We`ve got a pair of 3240`s sitting on the shelf at HKS Europe if we want them but I haven`t even had a chance to let the R32 rip up the 1/4 yet so I wouldn`t think of changing up for a good while.
I have found out that our ex-Sunyou R32 ran a 9.6sec in Japan which is very respectable:) but until more infomation comes through I`ve no idea if that is its best time ever?
Our car is due to go on the Dyno Pack in a couple of weeks,so I I`ll keep you posted on our progress.
Happy New Year Oz!!!
Henry.
    • Sorry I haven't been following all the detail, so you may have tried this. Does it idle with the tiniest bit of throttle you can add? You've mentioned the IACV, does it have an AAC valve and have you adjusted it at all (ie, screw the idle adjust screw all the way in, then back it out a couple of turns until idle is stable)?
    • My bad, I unplugged the one underlined in red instead of yellow before. With the car started, after unplugging the IACV (the one underlined in yellow), it idled at around 400/500 for 3 seconds before stalling. Attempting to start the car without the IACV will not start the car.   It does stutter and sputter for around 5 seconds before dying. However, immediately after starting it, you can already hear some slight sputters from the exhaust.   It won't start with the AFM unplugged. If it is when the car has already started, it stalls in a few seconds.   Yesterday, I did take some logs using Nistune of 3 scenarios. Car idling till it stalls Car idling and unplugging the IACV Car idling and removing the AFM I also have some previous logs of when the Car is idling till it stalls and when driving and it cuts. I am not really knowledgeable enough to understand what to look for. After every test, car idles rougher and rougher, until I have to stop. It will be fine the day after.
    • There is no difference between a 17x8 and an 18x8. The total diameter of the tyre needs to remain +/- the same (so you don't mess up the gearing, speedo reading, and clearance when turning front wheels..... so you just need to use a lower profile tyre on th 18 than you do on the 17. /rocket surgery.
    • I thought the same to start with. But then I thought it was one of those LCAs where the end of the ARB goes through a bushing in the LCA itself, instead of having an end link.
    • Yeah - I mean, go the other way. Smaller range. Not larger.
