Adjustable (Upper) Control Arm problems
Hi All
Has anyone else had problems with the lock nuts coming loose on the Adjustable Upper Control Arms that JMS sell (for the front of a R32 )?
The inner locknuts on mine keep coming loose... it's happened twice now and I have only had them fitted for a week !!
Has anyone else got a set of them fitted?
thanks
James
https://www.sau.com.au/forums/topic/7714-adjustable-upper-control-arm-problems/
Originally posted by meggala
you talking front or rear sorry I'm a bit dumb with suspension stuff but I have doen quite a bit of work on mine recently
opps forgot to add that important bit of info :mad:
Talking about the front
I rang them yesterday and they recon they havent heard of the problem before...
I was going to try some locktight on them tomorrow and see how it goes... and if that doesn't fix it them they can go back and I will just have to make do with the pedders Adj. bush kit fitted to the std arms.. unless someone can suggest some other option
(other than the UAS ones - as the review on AutoSpeed wasn't too favourable for their ones)
havent had that issue I would contact cause its not supposed to happen or use some locktight
cheers
Originally posted by JMS
Send it back to us so we can see if we can fix the problem if you dont have any luck with the Locktight. We havnt had any trouble with them yet  so yours is the first.
Regards
Terry
JMS
Cheers Terry
Will do,
But my biggest problem is that I am off on holidays wednesday night (and am taking the car) so need something in the car (and something safe) cause I will be doing a lot of driving (with my family in the car) so I am in a bit of a spot - need to fix it by wednesday.. Off to Tassie on the ferry, so cannot delay our departure :(
With my old std arms in place I have almost 5mm play in both front wheels.. so they are not an option...
If only you were in Melbourne... or me me in Adelaide...
At this stage the only fix I can think of that I might have any chance of doing by wednesday is to go with the local pedders fitted kit :D
(or maybe the whiteline one is the same I think)
Unless someone in Melbourne would happen to have a couple of std upper control arms they can lend me for a couple of weeks?? :)
regards
James
Ozdat
    • Great interview on damper settings and coil selection by HPA https://www.facebook.com/HPAcademy/videos/30284693841175196/?fs=e&s=TIeQ9V&fs=e
    • Yeah, it was a pretty deep dig.
    • The values for HID colour are also defined ~ see https://www.legislation.gov.au/F2006L02732/latest/text  ~ goto section 3.9 onwards ....
    • So, if the headlights' cutoff behaviour (angles, heights, etc) are not as per 6.2.6.1.1 without automatic levelling, then you have to have to have automatic** levelling. Also, if the headlight does not have the required markings, then neither automatic nor manual adjusters are going to be acceptable. That's because the base headlight itself does not meet the minimum requirement (which is the marking). ** with the option of manual levelling, if the headlight otherwise meets the same requirements as for the automatic case AND can be set to the "base" alignment at the headlight itself. So that's an additional requirement for the manual case. So, provided that the marking is on the headlight and there is a local manual adjustment back to "base" on the headlight, then yes, you could argue that they are code compliant. But if you are missing any single one of these things, then they are not. And unlike certain other standards that I work with, there does not seem to be scope to prepare a "fitness for purpose" report. Well, I guess there actually is. You might engage an automotive engineer to write a report stating that the lights meet the performance requirements of the standard even if they are missing, for example, the markings.
    • Vertical orientation   6.2.6.1.1. The initial downward inclination of the cut off of the dipped-beam to be set in the unladen vehicle state with one person in the driver's seat shall be specified within an accuracy of 0.1 per cent by the manufacturer and indicated in a clearly legible and indelible manner on each vehicle close to either headlamp or the manufacturer's plate by the symbol shown in Annex 7.   The value of this indicated downward inclination shall be defined in accordance with paragraph 6.2.6.1.2.   6.2.6.1.2. Depending on the mounting height in metres (h) of the lower edge of the apparent surface in the direction of the reference axis of the dipped beam headlamp, measured on the unladen vehicles, the vertical inclination of the cut off of the dipped- beam shall, under all the static conditions of Annex 5, remain between the following limits and the initial aiming shall have the following values:   h < 0.8   Limits: between 0.5 per cent and 2.5 per cent   Initial aiming: between 1.0 per cent and 1.5 per cent   0.8 < h < 1.0   Limits: between 0.5 per cent and 2.5 per cent   Initial aiming: between 1.0 per cent and 1.5 per cent   Or, at the discretion of the manufacturer,   Limits: between 1.0 per cent and 3.0 per cent   Initial aiming: between 1.5 per cent and 2.0 per cent   The application for the vehicle type approval shall, in this case, contain information as to which of the two alternatives is to be used.   h > 1.0   Limits: between 1.0 per cent and 3.0 per cent   Initial aiming: between 1.5 per cent and 2.0 per cent   The above limits and the initial aiming values are summarized in the diagram below.   For category N3G (off-road) vehicles where the headlamps exceed a height of 1,200 mm, the limits for the vertical inclination of the cut-off shall be between: -1.5 per cent and -3.5 per cent.   The initial aim shall be set between: -2 per cent and -2.5 per cent.
