Hi everyone,
Due to studies finishing, had to put up my baby for sale. Anyone whos looking for a fast car with a comfy ride may wanna consider.
1993 Toyota Mark2 TourerV (TT)
4dr Sedan
JZX90 engine (same as the Toyota Soarer)
auto
76000kms
white
Modded Exhaust
Sunroof
Dark Tint. (Sunroof is tinted blue)
Climate control
Alarm, Cd stereo, Turbo Timer
Excellent condition in and out
$14000 ono
Person to contact : Roger 0401664837 or PM
Car is in Crawley, Perth. Bought from Cannington car dealer 2 years ago at 55000kms. Gone thru 4 oil change includ. 2 services done by Xspeed. Never given me any troubles except recently, a minor fault where rubber is loose at the right headlamp, resulting in water droplets forming inside. Hurry, grab it befor I sell this bck to the dealer!!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
