***NEW*** Japanese quality engineered cooler kits for most models. ***NEW***
S13, PS13, RPS13, S14, S15.
HCR32, ECR33, ER34.
HKS Type-S
301x600x65mm
$1450 with free delivery
R33 GTS-T RB25 model shown
TRUST V-SPL
276x600x76mm
S13 model shown
TRUST R-SPL
294x600x115mm
$2350 with free delivery
BLITZ LM
Are these actually Real not take offs i need one for my rb25 wich will need to be able to support 250-300rwkw! got any in mind?
cheers
These are the genuine item shipped directly from Japan.
I do have a cooler in mind for you. You're looking for a cooler which accomodates up around 450-500ps.
Stay tuned.
cheers
The kits listed above are the only kits we bring into the country at this stage. Any specific orders may take time to locate at a desirable price for the consumer.
Charles.
Sometimes on the R33 the piping goes left then up , or then there is the 180degree bend going back towards the stock intercooler position. Which way is it? Hybrid style or 180degree bend style.
correction..
only Apexi that i know of has this bend.
perhaps somebody else here may be able to assist.
all of the kits i can bring in do NOT have the 180 degree bend on one side for the RB25DET.
not these particular sets.
also, HPI do a FMIC kits for all nissan makes. once again, straight out the side of the tank rather than the 180 degree bend on the end of the tank.
can get these in also for about $1600 landed.
    • All 3 I guess. The car came with the JASI Aero 4 door Type R Full Kit unpainted so this was one thing at the top of my list to complete then I noticed there were body panels parts for this kit so i picked them up along with some black mesh to fill in the front bumper and front side air vents. car is at a paint and body shop atm completing this work. Next I will be addressing the internal bells and whistles, great summer project I can do with the kids.  full interior removal - ,boys car sound deadening - pads and spray ,boys stereo, sound, lighting - Big 3, GTT or bigger alternator ,kids head lining - dye black add star lighting mod ,daughter. That's it for the next 5-6 months. I have some motor maintenance  work i have to plan out. oil filter relocation, gaskets, mounts. beyond that, mind is starting to turn over if i can use a DET intake plenum, block off turbo ports & pipe in a air intake.
    • roller coaster of a ride. Alarm system was removed & main harness was repaired where possible. still no fix just random successful starts. moved on to the replacing the ignition switch and relay. well all this troubleshooting & repair has been going on, the car is at a paint and body shop being pushed around. Ive been going down there on odd days after work to get it sorted.
    • 5th November if you want to come out for a spin wakfield
    • PROBLEM WAS BROKEN COOLANT SENSOR!!! Replaced with a new one and its running mint.
    • I think he was only proposing to use the wire, not the sender. Simply because it runs from the right place to the right place. Personally, I wouldn't hack up the factory wiring like that. I'd just lay in the Defi loom.
