  • Replies 52
all the best jon, you and your baby will be missed, I am sure u will be rapt to get her back on the 7th. watch out for all those vic coppers, they arent known for their tolerance or friendliness... sure hope you like AFL, cos the victorians are one eyed about it!!!! (league gal myself)
Only ever met you once but i think you were the first person off the forums i talked to. All the same, have a good one mate!
I think you meant to say "he was the 1st person off the forums that WOULD to talk to me" :uh-huh: :Pimp2:
oh sorry my bad, i thought you were Lee. hahaha jokes Lee!
you say i am a bad speller... well its true i know but at least i can spell peoples names right and considering mine is under every single one of my posts you are up their with me now :uh-huh:
wtf cassi? I dont see how you say your gonna miss him, you said to my face the other day that he was single handedly the biggest asshole on the face of the planet, and there will never be a bigger asshole than him.....remember you even wrote it down for me..... then made duplicate copies...... so that if you ever changed your mind i would have to show you the copies to remind you just how much you hate him!
Jeez your so 2 faced, i thought better of you....
bahaha :crazy:
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
