r32 engine recondition/repair
can someone please help me out. i have a 1992 r32 GTS (non-turbo). the timing belt has slipped and it seems my
engine is stuffed. so i am looking for someone who knows their stuff that could recondition/repair it. if anyone
knows of any place in melbourne that does this sort of stuff with skyline engines can they please reply, as i want
to get a few quotes from people who know what they're doing before going through with it. so far i have been
offered a fairly high price, so any help will be greatly appreciated.
looking forward to ur help.
https://www.sau.com.au/forums/topic/7791-r32-engine-reconditionrepair/
i'm with just cars... i pay $600 /yr
and can't afford any more than that
(and that's only 3rd party too)
...how much would it cost me all up to put that engine in?
i do want to get some quotes on repairing/reconditioning my engine too though and then compare and decide...
i'd rather get my engine rebuilt new than get a used one (as it may have been thrashed...etc)
not sure... i would say that it would probably cost more as u would have to pay for a new engine (unless doxxeh feels nice and wants to sell it for a couple of bucks :D) etc
worth a look tho man
Originally posted by inark
u could try ICE in dissik st cheltenham for a quote... generally deal in Hi Performance cars like lines etc.
im sure there are others
i couldn't find ICE in the yellowpages uner "engine reconditioning"...can you pls give me a phone number? thanks
do a search in this forum for ICE and u will find em...
cant remember the number and stuff... someoen made a post last week looking for their contact details so it should pop up in the search.
1 more thing... there was a limited number of R32s released with the RB25DE if im not mistaken which also proves they should swap over quite easily in the way of room.
try www.meggala.com one of the locals webpages... should be lots of info on lines and stuff.
it says at http://www.meggala.com/meggalacomnew/frames1.htm
that the RB20DE is a free reving engine. so does this mean that if the cam belt slips, the engine should not be damaged? could the ppl i took it to to have it looked at be shifty and just saying that?
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
