My s2 R33 gtst is only running at about 3-4psi instead of the factory boost level. I can hear that there is a hole or some sort of leak somewhere near the engine.
Modifications include only exhaust and pod filter. I did have standard boost until this little problem.
I took it to a local exhaust place in brookvale and got him to have a quick look at it (after he told me he doesn't do turbo cars) and he said it seems to near the manifold. He recommened another local performance place called Joviant but unfortunatly there were closed yesturday and today.
I need to get it running properly before I start work at uni on or around the 7th Jan.
I've heard good things about Hills but have also heard they take forever and a day.
Does anyone know my what my problem is, and can they refer me to a perfomance mechanic near the northern beaches that doesn't charge like a wounded bull.
I prefer not going to the dealer in Manly I bought the car from. I remember him telling me there was a boost leak when he drove my car back from botany warf but said it was fixed. I guess he didn't do a good job or something because in the last week its come back and the car is out of warranty.
Mark
Which freeway was this?
If it was anywhere near Eastern Creek the other day for the track day I only saw the pink justjap car which stood out like an altar boy's errection. I also spotted a local GTR arriving at eastern creek as I was leaving (purple GTR with zila number plates - 400+ kw).
Sorry I seemed to ignore you (I didn't see you). I was more concered not ending up on some highway to hell. As mentioned in the eastern creek thread I had no map and was unable to find someone to follow. Thank God I saw the justjap car pull onto the m4 because I was traveling in the total opposite direction =)
I might have to get one of those GPS systems if I want to travel outside the safety of the northern beaches.
Sure it was me PVA?
Mark
Mark,I think it is your tube that runs to your BOV. Make sure it is connected all the way to the plenum chamber as the tube that comes of the plenum can be missed when putting back everything.
Give me a call and you can bring it round for me to look at.
Doc
Check the boost guage sensor near the brake powerbooster and see if the small hose has split.
I think the R33's are the same as the 32's in that aspect.
Does it still feel like it pulls the same or similiar?
If so that is what it is..
  • 5 weeks later...
hey dude, is it a boost leak or an exhaust leak?? coz if its dropped boost and the exhaust place has told you he doesnt fix turbo cars, i got my money on you have blown your manifold to turbo gasket.
keka18 you are correct.
In another thread I mention that I got it done at Envy Imports on the Northern Beaches. They charged me nothing to fix it because I have done business with them before and I also got a front/dump pipe + hi flow cat and they high flowed my turbo at the same time. They are also doing a FMIC for me within 2 weeks.
I've also got a leak at the muffler which they said to get fixed at any exhaust place, so when I get time (working 6 days a week to fund mods) I'll get that fixed too.
Mark
    • Thanks @Duncan Ride height is fine. I think it's almost stock tbh. Happy to share a pic. I don't actually have a regular mechanic as haven't lived in Sydney too long. Could you or anyone recommend any shops in Sydney?
    • You just need a different blue slip shop (preferably one you regularly use as a mechanic), and make sure the coil overs are as close as possible to standard height
    • yeah the sugar refining companies were pushing for the same in Oz originally, all fuels were going to have 10% ethanol to make them "cheaper" (noting, that the loss in l/100 might be greater than the decrease in price). I guess they won that fight in Canadia
    • GTSboy, thank you again. i’ve been reading all the other SAU RB25 vacuum line threads and you have the utmost patience for people asking “where do my vacuum lines go”. it’s appreciated. i did also enlist a few other RB guys local to me.  i would like to run 5 to 4. turbo pressure side to wastegate actuator. i would like to run 3 to 1. power steering air valve line to intercooler outlet. (this is how it was previously). i was told 2 is the bleed port for the boost solenoid - which i’m not running - so should be capped.   anyone see any problems with that?
    • So yes. All of them. Something like 98% of all fuel in the USA has 10% ethanol: https://afdc.energy.gov/fuels/ethanol-fuel-basics It's labelled as like, AKI, 87, 91, 93 with an E10 or E5 or E15 label on the pump. At a certain point, it's not just "E10" instead of 91. It is 91, 95, 98, and all of them have 10% Ethanol in them. You can also get E85 and E30 which is why you do see some people rolling around with E30 tunes in them.
