CLEARANCE...
EVERYTHING MUST GO! MAKE WAY FOR NEW STUFFS! :)
PM ME IF YOU ARE KEEN!
PIVOT RACING METER SERIES 60mm - RRP$250, NOW$179 ONLY + FREE DELIVERY (SOLD)
-It has seven colours multi-lighting system.
-The colours are white, red, magenta, yellow, green, light blue and dark blue.
-White Face dial.
-60mm Machine Finished Aluminium Bezel
-Very accurate and looks very cool with the aluminium front ring.
-Lightweight, Thin Body
-Easy Installation
-Chrome Bezel
-Accurate Response
-The Pivot Racing Boost/Vacuum Meter comes with everything you need to mount it, including brackets, double-sided high-strength adhesive, zip ties, vacuum line, and wiring harness.
PIVOT TACHO WITH SHIFTLIGHT - RRP$350, NOW $279 ONLY + FREE DELIVERY (SOLD)
-The Pivot Tacho meter with shift light come in 80mm diameter size.
-This meter has meet the stringent requirement of rally and circuit race.
-Pivot racing tacho:
*has accurate reading
*use reflection diffusion-type lighting
*easy to read even in a high-vibration situation
*has Green Illumination Provides Easiest Readability
*is of lightweight design that Reduces Vibration
*has Internal and External Shift Indicators
*Mini-Console Unit Allows Adjustable Shift Point
PIVOT RACING BOOST METER - RRP$250, NOW $179 ONLY + FREE DELIVERY
-The Pivot racing meter series comes in 80mm dial face.
-Easy to install.
-High response Gauge and Display
-The Pivot Racing Boost Meter comes with everything you need to mount it, including brackets, double-sided high-strength adhesive, zip ties, vacuum line, and wiring harness.
open To Offer... Any Reasonable Offer Will Not Be Refused! My Cusco Shipment Has Arrived And I Have No More Place To Put Stuffs.. All Must Go!
LEFT THESE 2 PIECES ONLY
1 x PIVOT RACING BOOST METER - RRP$250, NOW $179 ONLY + FREE DELIVERY
1 x PIVOT TACHO WITH SHIFTLIGHT - RRP$350, NOW $279 ONLY + FREE DELIVERY
ONLY THE FOLLOWING LEFT! 1 only :mad:
-Easy to install.
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
