Hey guys
Thinking of sell it as i didn't get chance to drive this car.
all it does is sitting in my garage collecting dust, i better let it go to a new owner who will DRIVE it.
2002 Nov Nissan 200sx - S15
only 2 & 1/2 years old
still under factory warrenty, one of the lastest s15 u can buy
Pewter, spec S GT
with optional spec R side skirt
6 speed manual
very low 29xxxkm
service every 5000km
only with motul 300V and redline oil in gearbox, diff
weekend car
Non-Smokers and garaged every single day in it's whole life!
tinted window
Electric windows
keyless entry, centre locking, Factory Immobiliser
being a GT it equiped
"GT" wing (Jap spec)
leather interior, leather steering wheel, gear knob
chrome door handle and sport pedal
chrome wheel
etc
exhaust technology dump, front pipe
high flow cat
X- force titanium catback exhaust
Pod filter with Apexi Aluminium heat shield
High flow GTR fuel pump
Apexi pen style turbo timer
Exedy heavy duty clutch
lower Kings Spring (legal limit)
Blitz BLM boost gauge
car is immaculate, as expect by her age and km done
All modifications are brand new and undertaken in the last year or so.
I am asking $31500
Anybody interested pls contact me via pm
Edited by Maxx
https://www.sau.com.au/forums/topic/78318-2002-nov-s15-spec-s-gt-180rwkw/
  • 3 weeks later...
very nice example, and a good price for all the mods included!
we bought ours in november last year which was also a 2002 spec S GT pewter but it was stock for $37k and 15,000km on the clock.
If your one was on sale back then we would have bought it straight away :P
now a question, 180rwkw is pretty good for a stock? ecu, what dyno did you get that on? and what boost are you running?
free bump!
feel free to pm me if you want.
cheers.
  • 3 weeks later...
  • 4 weeks later...
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
