I have a Complete HKS triple plate clutch and flywheel in excellent condition for any RB series engine. It is a push type so is perfect for any big hp GTST.
I should have some pics up later today.
$1,200 neg
Email, [email protected]
https://www.sau.com.au/forums/topic/78463-hks-tripple-plate-clutch/
Only on a std organic single plate have i seen close to 4mm of clutch material and then they have rivits that hold it all together. These are bonded.... note the lack of rivits.
Think about your statment for a moment.
we'll be generous, if there is 2mm missing off each side of the clutch plates,
3 plates with 2mm off both sides means
4mm toltal off each plate which when multiplied by 3 plates is........
12mm total worn off
How many clutches have that sort of throw in the pressure plate arc?????
At any rate I will get it checked at Race Clutch Tomorrow and we will see just how stuffed they are.
My bet is there in pretty good shape.
    • If you are Ecutek tuned then these TCU tunes are anywhere from $550 to $700 usd. If you are not ECUTEK tuned, then it gets costly!
