Hey guys, i've done a bit of a search but couldnt find much.
Anyway, just brought a tacho, and now im stumped as to how to wire it up. My original tacho only worked sometimes, very rarly. I've gone behind the cluster, and touched on the wires to the tacho to see if i could get signal, however couldnt find any on anywire.
So basically i want to know how to wire this tacho up? Can i grab it straight off the ecu? (im an Rb20E)
How has everyone else done it? is there any specific colours that the tacho wire usually is behind the cluster. Im lead to believe that a GTST cluster could go in, so it should be the same in theory...? kinda.
Thanks.
Dayne
https://www.sau.com.au/forums/topic/78502-wiring-a-tacho-r33/
You might have problems depending on the tacho type.
Basically you can try hooking up pin 7 as the signal wire and if that works you are laughing.
If that fails you can try a pull up resistor, then a tacho booster. Get back to us if you need more info on the last two.
Actually, speaking of the tachos, what form is the ECU tacho output? Is it the same as a central distributor lead in other cars? The reason I m asking is I was trying to hook up a rev meter to my car recently and according to the manual I needed to use a wire that hangs out next to the O2 sensor connector (that was designed for that purpose). I did that but I was getting the signal that was about 6 times less than the actual rev figure. I guessed it was only a signal from one spark plug, not all of them.
Funny thing about doing that is that my tacho was going crazy while I had the meter hooked up. It was showing the right idle but going crazy while revving - it was dropping to zero. It actually looked as though it was working in "reverse"
So now I m wondering if I can hook up the device to the ECU... Not trying to confuse the OP
Yeah i dont really know what that means, if you could fill me in a bit more it'd be great, im going to go try 'pin 7' now and i'll let yous know.
Dayne
Pin 7 is the signal wire that the OEM tacho uses (also need +12V and GND).
Some tacho's will work fine if their signal input is connected straight to Pin 7. Others don't work straight away and need a bit of fiddling, it just depends on the tacho. It seems less likely that the tacho will work if it was designed for a coil type ignition (eg some US tachos and EFI conversions into older cars) rather than an EFI application (eg Jap tachos).
Well thats what my tacho says, "Connect to coil ra ra ra" so i think i might need a tacho booster? is that correct? where can i get these from?? or what type of fiddling do you mean?
Also... how do i find wire 7 on the ecu? you guys said it was a green one, but the only green one i can seem to find is way up the list.
Tacho output is a 0-5V square wave.
But...
All pin 7 does is switch between open and ground. So to get a signal you need to connect a voltage source to pin 7. AFAIK this is done internally in the tacho (+5V). If you don't connect pin 7 to a voltage source then the ecu is just switching pin 7 between open (0V) and ground (0V) and therefore you don't get any signal. The upshot is that if you have an OEM tacho, and it works, then the tacho connection should work.
But this is just background info and doesn't really answer your question.
From what I remember the tacho output is actually a cylindrical connector with a single pin, are you sure you are measuring from the right place and you're not measuring from the timing light pickup loop?
Try connecting it straight to pin 7 first, if its a new tacho it might be designed for universal applications.
If it doesn't work you will still need to work out which wire is pin 7 anyway, plus you will need a +12V and GND sources, so you aren't really wasting any time if it doesn't work.
Righto, so that's why you need a pull up resistor. Yeah, I was connecting to the single pin cylindrical connector lower down the left strut tower, not the pickup loop.
Because there are 6 individual coils in a Skyline (ie one per cylinder), which makes for some fun wiring it up and designing circuits so that all the signals don't interfere with each other. God knows the sort of trouble you could get into. It's not like a old single coil car where you just have to piggyback onto a single wire to get the tacho signal.
IMO its much better to mess with non critical instrumentation wiring rather than start compromising the integrity of the wiring thats essential for reliable operation of the engine (ie splicing into coil wiring etc).
If the tacho doesn't work straight out of the box, then a pull up resistor might work and that is going to cost about $1. If you have tried this and it doesn't work, a tacho booster will only take 5 min to install, but it'll cost $50-100.
Whatever option ends up working, you are still going to need to locate the tacho signal wire, +12V and GND, so you might as well start with the cheapest option first...
    • Given you're running a 2.8 and my 2.5 is not really like for like, I suspect there could be a bit more timing you could give it. What is the kW yield per degree you're putting through it? Here's my E85 map to give you an idea, where it was I could still get another 3~4kW per degree thrown at it.
    • It turns out that Setrab make a fan specifically for the oil cooler which is great and I've installed it with minimal swearing. I removed my 2x 12in push fans from the front of my aircon condenser and wired them into this. My main thermo fans kick on when I use the aircon anyway and would effectively already be working as puller fans through the condensor which is infront of the rad. The push fans (understandably) didn't really do much in the config they were previously in so now they're out. Now we're on to the "Oil fan doesn't really do much either!". Yes I'll duct it next if it does nothing in heavy use which it shouldn't. But hey, the object exists and fits great and is cool. Let me have this. The car is still in the "do my fittings leak oil now? do my wheels actually rub?" phase. I did a spirited drive on them and didn't hear or feel anything. Then I got back home and noticed there were grind marks on the inside of the rims, though I couldn't see where they were touching I got out the grinder and attacked the suspects. Note: I do not know how to use a grinder. Then I realised I had dragged my new rims across my concrete driveway before I did this drive. I didn't think I had damage at that time when I briefly looked...... but remembered this occurred after I did all the angle grinding. The grinding on the wheels in some very specific spots. It's not around the whole rim for example, which lines up with dragging it across concrete more than hitting a suspension component for even 1 full rotation. So everything is currently painted and taped up and I need to test it some more to see if it really IS rubbing, but from inside the car it doesn't feel like it is. In other news I attempted to do a before and after comparison of the heads/cam upgrade thing. Dynos lie, everything is in different measurements. Here is the data from the sandown back straight. Car go faster than before. Vroom vroom.
    • Here's my base ignition. +3 correction to redline when shooting water/meth which is always on. Looking at my old ignition table, I should be able to add 1-2 degree's next time I'm on the dyno.  Let me know your thoughts.
    • Given what I know now - same haha, but this was 12 years ago with second hand 740cc Nismo injectors in my S15 daily, I was too busy hunting elsewhere for the issue to even look at the injectors, running through some cleaner was a happy coincidence haha
    • Not a terrible idea. But if I ever had concerns that my injectors were sufficiently dirty to be causing me a problem, they would be out of the engine and onto the actual injector cleaner/testing bench.
