Heys People,
Well im here to sell or swap my car for any thing that i might be interested in.......
On the 13the of this month my car was an an accident, and now it is up for sale...
THINGS NEEDED TO REPAIR
- Radiator
- Radiator Support
- Passenger Side Headlight
- Bonnet
Nissan Skyline ECR33 GTS-25T
- Built 11/1994
- Gloss Black
- 88***Klms on the body
- 56***klms on the new Nissan Skyline Series 2 motor
- 5 Speed Manual (With TOMEI Short Shift Gearbox)
- NSW, Sydney,(Liverpool)
INTERIOR
- RAZO Pedals
- RAZO Gearknob
- AUTOMETER Boost Gauge
- GREDDY Turbo Timer
- HKS Electronic Boost/Valve Controller (EVC Type 1)
- TOMEI Short Shift Kit Gearbox
- Excedy Brass Button Clutch (Installed by Maureen Motors on 23/9/04)
- Rhino Alarm (with pager) (Installed by Desire 4 Sound on 6/7/05)
EXTERIOR
- Professionally lowered 3" by Tempe Tyres
-Full Body Kit (Professionally fitted by BODYFORM in Lansvale)
which consists of-
- Trial Front Bar (Currently fitted to the car)
- VeilSide Front Bar (NOT Fitted)
- NISMO 400R Back Bar (Wider and Lower Appearance)
- NISMO 400R Side Skirts
- TRUST Stealth Wing (from BODYFORM)
- 15% Tinted Windows (tinted by Premier Tint on 6/7/05)
- Stock (R33/200sx/Maxima) Rims (with tyres)
ENGINE
- Serviced every 3000klms with Shell Ultra (Edward Lee's Japanese Auto Centre Concord)
- NEWLY FITTED RB25DET FROM A 1997 M SPEC SERIES2 R33 SKYLINE WITH ONLY 54***KLMS ON IT
- JDM KAKIMOTO 3.5" Turbo Back Exhaust System
with 5" HKS Muffler
- JDM KING DRAGON Type 1 Turbo Air Filter
- NISMO Custom Front Strut-Brace with Nismo Brake Increaser
- Custom NISMO Brake Increaser (Smoother and Higher Response From Brakes)
OPTIONAL STEREO
- KENWOOD Japanese Double-Din Head-Unit (Play CD-R, CD-RW)
- ALPINE 6 Disc Stacker with Remote and LCD control unit (Plays CD-R, CD-RW)
- MTX 15" 1000w Sub-Woofer
- MTX 444 ThunderBolt Series 1100w Amp
- CLARION 6" 220w Rear Speakers
- CLARION 6" 170w Front Speakers
- CLARION Tweeters (with Crossovers)
NOW ***$11000 ONO***
OR ANY SERIOUS OFFERS!!!
Well thanks for having the time to read all of it. Any questions u know what to do.......................
Or call me on 0401299729 or 0424678535
Emails or add me on msn -
[email protected]
Thanks....
HOPEFULLY SHE CAN LOOK LIKE THIS AGAIN!!!!
gday, i have seen this car cruising around!
very tough looking car, nice ride!!
free bump!!
but im sure i saw it with rims on it, not stockies?!?!?!?
anyway, lovely ride! will call u sometime soon!
Legacy GT Wagon, Constant all wheel Drive, Boosted to 10PSI EJ20T Motor water/air intercooler, Leather interior, 17" Rims + $1000 cash.
Im in Perth however! Gawwd damn it..
intrested in swapping a 98model VT Commodore Exec with R8 255 custom running gear with $3500 spent on Auto transmission, one of sydneys best sleepers going round :) (254kwz @ the wheels)
sorry to hear it man..
maybe post some pics of the damage up and if possible, a repair quote.
then people can offer accordingly.
is it still driveable?
is it registered and if so, for how long?
and how did it get stolen with the alarm with pager you have?
cheers
yeh ive had a non painted rear quarter under my fuel lid......and thanks u guys but shit happens.wat can we do but .....im sellin or trading it stil
for any car......yeh im from Liverpool,Warwick Farm to be exact.........
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
