hey guys,
for the past 2 days, ive been cleaning some big mess of wires under the carpet and seats of my car.
guess at one point it had some major audio system on it and the owner never botherd to clean up, so i come & try to install a head unit with some rear speakers and i had to deal with a whole shitload of lose/cut wires!:(
i started it finaly after a few cranks "which is odd" but didnt think of it,i take it out and went for dinner, everything is ok as usual.
later on on my way to home, it almost stalled,the car doesnt have the same power at all and its sound changed to poping and metel-like rumbling.. barf!!
parked it home, turned it off and on again, still the same..
i checked the i/c piping,nothing! :confused:
here is a video, sorry its realy bad, but u could still hear it
http://www.megaupload.com/?d=247DTZ2A
it is stock by the way only an intake & a cat-back "and been runing rich like a MOFO!!:bonk: "
any ideas?
thanx guys,,
  • Replies 57
Sounds like one or more of your spark plugs have fouled up. It happens when your car runs rich or you have been idling a long time. Remove all 6 and check which ones are really black, you'll spot it.
Replace those ones and while they are all out make sure the gaps are correct.
Refit the plugs & she show be sorted out.
spark plugs??
but i didnt even put 100 klm on em they r new ngks and gaped to 0.8
btw...
you got the sweetest car!
I HATE YOU!!
Thanks for the complient - I think.... :confused:
Could you of cut some wires that you shouldn't have, maybe a sensor wire, ground wire or something. Must be sure of this.
Usually your sort of problem happens with fouled spark plugs. Couldn't hurt to check cause I dare say one or more are all fouled up.
:uh-huh: :wassup:
will do! :(
now that i think about it, am almost sure it has to do with the wires, coz it was runing flawlessly b4 "except for the runing rich part!"
the thing is.. i wouldnt know where or what to look for!!! coz i had all boot lining,half of the dash, front & back seats out, and the carpet on both sides!!
Start at 1 point and slowly go through any wire you could of touched. Any cut off wires, make sure you know what it is for. You must be patient. It's going to take a while especially when your surpect of some wire and have to find out what it is.
But think of it this way, if you get someone else to do it, imagine the bill......#$#$.
There is an all workshop manual that can help you out for things like this.
Eventually you will find it and all will be good.
Good Luck
P.S. Still check the plugs though, before anything, easier to start there, then going through all your wires.
also check all of your coils... I'm not sure of the set up of yours but some are prone to cracking if you overtighten them... also if you changed them 100k's ago, is there any chance of water ingress etc?
things like this suck, it could be wiring, or it could be coincidence that it just happened after you were playing! good luck with it dude.
I agree with wet, check the easy (simple) things first!
thanx for the input guys..
i 4got to mention that my new rear speakers stoped working , and am sure they were fine some time last night, b4 this shit happend! talk about a coincidence!
am going to check that 1st, even though i dont see any connection!
ok, its 4:19 am over here, and just took my plugs out..
cant tell if they're good or bad for shit! am bad at this..
are these what is causing this problem??
all tips are fine, only some discoloration on # 1 & 4
also, my bro is the one who gaped them, to .7 not .8 like i asked him,
said its not a big difference.
so now am just gna be waiting for help so i coud go back out side.
aint sleepn with my baby all opend up! :gaga:
Hi there,
OK, no.1 looks fouled, I can't see no.6 but no. 4 looks ok.
I see that you got the NGK BCP7E-11. In future get the BKR6E. The 6 means a hotter plug & better burn. These are also the ones I run in my car. The -11 means that at factory they were gaped at 1.1 so even if you got the BCP7E they would of been gaped at .8 & gaping them means a small bend.
If all was good & you have just recently installed these (100km ago) they should have looked exactly like 2,3.
It's up to you what you would like to do, but trying a new set of plugs is a good start & even if it's not that, well you'll have them just in case you foul any plugs (happens to Skyline alot) and they'll be there for your next service anyway.
Now your plugs are out, check all your coils for any cracks, examine closely.
heyyy! THE PIC IN UR SIGH ON THE RIGHT ISNT UP THERE!!
NOT FAIR!
I was in a rush, but your right, bad angles. I thought my pic of signature was in my photo's, I just checked - its there but it bigger
    • Im not entirely sure exactly what or where its leaking from, he started to pull the boots to swap to my new tie rods + ends and it just vomited fluid, so he closed em up up, swapped the rod ends to the old rods and let me know so I can figure a solution out, im guessing its all origional as as I passed 103k miles earlier this year im sure its just in need of a full overhual/rebuild anyways.    If i could just yank it off and be good it wouldn't be an issue to ship it out and wait for the turnaround but the guy I work with doesnt really have space to keep my car for a week or two at a time, would rather drop it off and have a replacement ready to drop in
    • What do you mean by "seals"? Internal hydraulic seals (ie, is it leaking PS fluid?) or the rack boots that close the rack onto the tie-rods? Because the former is a rebuild, and the latter is trivial that you or any nearby mechanic could do. Dunno about the cowl. Just buy what you think is required and get anything else you find/break afterwards. Wing? Dunno. Don't like R33s enough to pay attention to them. Mirror glass is just glass (on the surface that you want to polish). Go for it.
    • Hello! Long time lurker, been using the forums to address concerns and questions from afar for a while but I've struggled to find some answers so I guess its about time I made an account and formally asked some more knowledgeable people, since finding local skyline owners is hard (and shops that are knowledgeable or trustworthy to work on 'rare' cars are non existent out where im at, as skylines are quite uncommon to find in the wild around here). So the main 3 questions I have, 1: Steering rack has blown seals, well.. they kind of hold but they are not sealed properly anymore and as my R33 is my DD, i cant exactly rip the rack out and send it off or attempt to fix myself. As most refurb ones are around $1,100 or more shipped, and I have other things I need to work on around the car, I was seeking clarification on whether an S15 rack will more or less bolt right in, and whether a common mechanic could do any other required work to get it to fit. I ask, as I've found a supplier than can sell a manufactured as oem one for around 400, if not I'll likely order a used one from Jacks JDM, and take a risk on the seals there. The second question i have is that im replacing the front wiper cowl and have planned to buy 4 new clips and a new center clip but wasnt sure if there were any other clips that would also need to get replaced while I was at it. Given im sure any that are there now will simply break when I remove the old cowl... Last thing would be a fairly straight forward question, i think. If I manage (strong if, finding one has proven to be a pain) to find a R33 GTR spoiler/wing will it require much modification to bolt to a S2 R33 GTST? I've read the bolt patterns dont match but otherwise would bolt in, only options I have found with much luck is China stuff on ebay and carbonetics, which has a nice $650 shipping fee... so if anyone has any pointers where a US chap could locate one that would be great Random side question as well, the mirrors as I understand are mirror glass, and as im planning to polish my windows from water spots and surface scratches, i was hopeful cerium oxide would be fine for them too, as my research points to, but clarification is always nice. Any pointers would be appreciated, and while I have scoured the internet for answers if I missed a prior post somewhere that may answer these directly please point me towards it, as i must have simply missed it. I have seen a post here or there that has mentioned it, but I usually get 50-50 answers, or half answers... I dont have a lot of fab experience or mechanic experience, outside of hydraulic and pneumatic stuff I did in the military and with how hard it is to source stuff in the US, id rather not wing it and hemmoraghe money lol. Thanks guys! Sorry for the monumental first post haha
    • Yep, there's a very minor drift left that happens a few seconds after letting go of the steering wheel, but not enough to bother me. Enjoying the car still!
    • Got you mate. Check your email!
