  • Replies 57
It's the resistor pack for your injectors. Its there to change from high impedence to low impedence. If any wires are shaved, try repairing it. This unit can be removed for repair, but for now lets try fixing the problem you have now.
Check No.1 coil very carfully - something might be there
Photo's are there now.........
i already got a new set right here! i just bought some extra ones last time i changed'em,
but they are the same ones ( NGK BCP7E-11 )
also, is it ok if i kept the gap as it is? coz i never gaped one b4, and if i try and end up breaking one am going to be a plug short! hehe!
btw, i couldnt thank you enugh for ur time. uve been a big help
No problem, thats one of the reasons why we are all here, share, talk & help.
Your plugs must be gapped down, its not hard it you have a filler guage. I can guide you through it if you like.
been reading a few threads, and i found this one:
http://www.skylinesaustralia.com/forums/sh...ghlight=misfire
almost the exact semptoms. i realy hope its not a gasket
OK, I have read this post. This is true - if your car runs very rich, it will misfire but if you replace the spark plugs - as I have suggested - it will run fine for a while until it misfires again but we at least know where to start looking.
In any problem solving, process of elimination is your friend. We have to check what works to find out what does not.
P.S. Gapping plugs with even a good Mallet, hammer, brick is a health hazard....... only qualified professional machanical engineer technican should use these devices.
is this what your talking about? coz i found one! loool
Thats the one!!!! Even people like you and me can use this, no qualificians necessary.
1. find 0.6 filler guage.
2. on something soild like a metal bench, tap the spark plug with just enough force to shorten the gap.
3. Contine doing this & check with the filler guage.
4. If you over do it just use the filler guage or something else to very slightly open it up.
5. The filler guage should slide in without moving about or move very slightly.
In your situation because you have 1.1mm gapped plugs, measure from the tip of the spark plugs, they have to be bent a far bit - this is why the BKR6E has a factory setting of 0.8mm gap, better and easier to gap to .6 or .7. Another thing, the 6 is a hotter plug, does not foul as easy as the 7 plug range.
0.6 is probably a touch to small, the gaps on modded GTR's i've heard used are usually 0.65mm-0.8mm... Not sure about 0.6mm but can't imagine it making a huge difference either way - why not aim for the middle of that - say 0.7mm?
oops sorry, I meant 0.7 as your other spark plugs were gaped at these & 0.7 is a good gap to keep. Mine are at 0.6 but I have alot more boost & fuel to iginite.
Sorry about the confusion
    • Yeah, plenty of air flow, there is a dedicated path that feeds the air in to the OEM intake tube behind the bumper As for a "tangible effect", maybe, but getting the pod/intake air out of the hot engine bay is worth it psychologically to me, even if it gives no performance difference, so the tangible effect in my Lizard brain saysss yessss  In the end, to me a tangible effect isn't always about performance, sometimes it a sound or a look, or even a...... feeling  Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga
    • yeah first and reverse is where you will find clutch release issues (whether hydraulic or mechanical) because the difference in revs required is the highest there; particularly changing down from 2nd to 1st when still moving. To be clearer though, it is possible that the clutch release bearing is the wrong height. This is less likely than a hydraulic issue but it is not unheard of when you are mixing and matching
    • Quite right, if you make it to that pension you deserve every cent
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
