hey all cefironites,
hope your rolling well in oz, i'm in the land of the stinky hot weather of jakarta dodging terrorists and pirated dvds by the million. well ok maybe just the dodgey dvds.
heaps of neat and plenty nasty cef's over here, tonnes of glorias and various other nissans... been interesting driving round here again.
byeeeeeeee
https://www.sau.com.au/forums/topic/79236-kursed-in-indo/
hey dude. Can you do me a MASSIVE favour then. Go down to the local cef wreckers. Now you know the clips that hold the sunvisors in? The ones on the end of the visor that the little round thing clips in to? Can you grab me a drivers side one of them?
And when you get back I'll give you money, hugs, first born, and postage for it or something???
Just the sunvisor keeps falling down and hitting me in the head.
https://www.sau.com.au/forums/topic/79236-kursed-in-indo/#findComment-1444596
Sup kursed!!
Good to hear from ya buddy.
Hey can you do me a favour? ... go to the wreckers and pick me up the left hand side vent surround that is always missing, the middle vents, and the little 2 outter vent grills (the little ones that point at the driver and passenger side mirrors to de-fog the field of vision to the side mirrors).
Cheers man - oh.. and I think every single person with a cef will be interested in those grills - but remember who asked ya first :sly:
Heheh good on ya man :P
https://www.sau.com.au/forums/topic/79236-kursed-in-indo/#findComment-1444768
ha! i'm on holidays guys, not trawling wreckers in the indo heat. dunno if many of you have been there but its peak of summer here and about 5billion degrees too hot to be sifting for elusive car parts.
see yall when i'm back :(
https://www.sau.com.au/forums/topic/79236-kursed-in-indo/#findComment-1453624
    • Perfect, I'll get to it this winter then at the same time as I weld on my anti squat kit.
    • Alright so my 32 only has one temperature no matter what degree you set it to. I’ve tried disconnecting the servo motor arm and moving it either direction and got no change. I’ve fixed the leak in my AC and re charged it and with it on and clutch engaged it still blows hot even though the low pressure pipe going to the firewall is ice cold. Both heater core hoses are hot while running as well. Diagnostic code showed 24 for intake air temperature sensor. Anybody got any ideas?
    • I said Garrett style. Not Garrett genuine. And something in the G30 550 range is what you want. Not those pokey little old fashioned T28 sized things. The intake ports in the head are small. There is little benefit in fattening up the runners and leaving ths actual ports small. Just run what you've got. And on the subject of Nistune vs Haltech etc..... You know you can control the transmission with decent standalone ECUs these days, right? No need to keep any of that old Nissan bullshit. Don't get me wrong - I use Nistune on my Neo. But it is a DET, so the number of bodges and workarounds I had to do to make it work in a chassis without ABS, TCS, etc, is quite small compared to the herniated arsehole you will have trying to make it work on a motor that doesn't have some of the things that the turbo ECU wants to see. Just easier to bite the bullet and go aftermarket outright.
    • Hmm. Only when the f**king thing is actually working. Still can't find the leak. And that's with dye being put in the last 3 times!
