The find more posts by user fucntion doesn't seem to be showing up any posts from after Jan this year. If i search for posts by myself from my profile it doesn't show any posts made in the last few months, even though they exist. Same if i try searching for other users posts....
PS can someone please fix up the anti-aliasing on the icons/buttons used on the blue background - they look shocking with the white pixels scattered around the background :)
https://www.sau.com.au/forums/topic/79460-find-more-posts-by-user/
That doesn't work either :)
I click on your name, i hit 'find more posts' it comes up with posts from march this year.
I click on your profile, and hit 'find all posts' it comes up with the same results - march this year.
I'm pretty sure the 'find more posts' used to give all posts as well :)
Try it on me - Go to my profile, click find all posts, and it will only come up with posts from November and earlier?
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
