Greetings all - yes , my first post on SAU, have lurked here for some time though being a fan of Skylines and all. Who isn't?!
ANYHOO:
It's that time of year again - the Altezza Club are holding another Ian Luff Stage 1.5 Advanced Driving Course at Oran Park.
For those who don't know, the Ian Luff advanced driving course is a chance for you to get out and learn the basics of how your car stops and turns on the limit in a safe and controlled environment. And it's bloody good fun!
Basically, our club books an Ian Luff day each year, catered specifically for our club and other like minded clubs to get out on the skid pan and learn a few pointers about car control.
Why Stage 1.5? Because this is a car club orientated day, the Luff crew throw in some stage 2 cloverleaf, slalom and skid pan to go with the stage 1 stuff.
Details on the Altezza Club forums, including how to join in, here:
http://forum.altezzaclub.org.au/index.php?...p?showtopic=760
Here's some testimonials from the last one we did last year (and some tasty pics to salivate over.)
note the lack of Skylines.... we would like to see some NISSAN POWA on display this year!
http://forum.altezzaclub.org.au/index.php?...wtopic=73&st=40
PM me for more info, or post to this thread. Please, firm commitments only, and only a deposit will secure your spot!
Cost is $250.00 for the day, with a catered lunch included!
Cheers,
Matt
https://www.sau.com.au/forums/topic/79503-ian-luff-stage-15-august-1st/
Yes, it's a Monday. Costs more to do it on a weekend, and that doesn't include lunch.
Details in brief:
Date: Monday, August 1 2005
Time: 830am -430pm
Cost: $250.00 (includes lunch)
It's the best Monday/sick day you'll have all year!
There is now only 1 space remaining on this course. Please email or PM me if you intend to take this coveted spot!
I also have 2 payments from people who have NOT emailed me to confirm their deposit. If you think you may be one of these people or if you have not received direct confirmation of payment from me and me only, then email me or PM me ASAP with details of your deposit.
    • Ok so after much research and talking with knowledgeable people I've got my turbo conversion done and it's all running great other than 1 small issue.  Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd. But nothing drive or what gear your in when you pop it into tiptronic.  I'm sure there is may e 1 wire in the ecu plug I need to move to rectify this. Dose anyone here have any ideas?   Cheers guys
    • Sorry I haven't been following all the detail, so you may have tried this. Does it idle with the tiniest bit of throttle you can add? You've mentioned the IACV, does it have an AAC valve and have you adjusted it at all (ie, screw the idle adjust screw all the way in, then back it out a couple of turns until idle is stable)?
    • My bad, I unplugged the one underlined in red instead of yellow before. With the car started, after unplugging the IACV (the one underlined in yellow), it idled at around 400/500 for 3 seconds before stalling. Attempting to start the car without the IACV will not start the car.   It does stutter and sputter for around 5 seconds before dying. However, immediately after starting it, you can already hear some slight sputters from the exhaust.   It won't start with the AFM unplugged. If it is when the car has already started, it stalls in a few seconds.   Yesterday, I did take some logs using Nistune of 3 scenarios. Car idling till it stalls Car idling and unplugging the IACV Car idling and removing the AFM I also have some previous logs of when the Car is idling till it stalls and when driving and it cuts. I am not really knowledgeable enough to understand what to look for. After every test, car idles rougher and rougher, until I have to stop. It will be fine the day after.
    • There is no difference between a 17x8 and an 18x8. The total diameter of the tyre needs to remain +/- the same (so you don't mess up the gearing, speedo reading, and clearance when turning front wheels..... so you just need to use a lower profile tyre on th 18 than you do on the 17. /rocket surgery.
    • I thought the same to start with. But then I thought it was one of those LCAs where the end of the ARB goes through a bushing in the LCA itself, instead of having an end link.
