Hey guys,
Im looking to buy a new clutch for my car seeing as my engine is coming out to fit the turbos and sump baffle.
What clutches would people recommend. Im really only after a single plate clutch. I want something that drives like the standard clutch, is light on the leg and is not on/off like some clutches. Ive called up race brakes and theyve advised me to get their clutch which is made up of a meva ??sp?? compound, rather than the organic compound. Clutch cost is $650 ?
Ive also called up jim berry, but the price for one of his clutches in a carbon compound is $1050 or something like that, and I do think thats out of my price range. Are there any other places in sydney that do good clutches for under the 1k price, that can handle up to approx 330awkw, and will be used mainly for street, and occasionaly track, and sometimes at the drags ?
Cheers
Also, seeing as my engine will be out, are there any other things I should get done to it ?
Cheers
Tommy
https://www.sau.com.au/forums/topic/79680-new-clutch-where-to-buy/
Just called them
They advised me not to get what race brakes advised, a meba clutch ? and to get a nismo clutcy type with a single plate button, 3 puk? and a stronger pivot? with a clamping of approx 1450-1500kg? cost $1050 :cheers:
I dont really want to spend that much but at the same time dont want to buy something thats not going to last. Clutches confuse me :P
mate, considering it's such a bitch to fit a clutch and also considering you are putting on turbos (more power) and sump baffles (track work) i would suggest a twin plate. 330awkw is not to be sneezed at and you will be pretty pissed if at your first track day the clutch starts slipping after 5 laps. you should be able to pick up and OS giken twin pretty cheaply, not quite as friendly as the nismo, but mine certainly cops plenty of punnishment.
I've recently changed from a twin plate to a jim berry single at around the cost your talking - if you supply him with your standard gtr pressure plate and flywheel it might make it a little cheaper. Only been driving the clutch for :cheers: and whatever you do make sure you get a sprung centre, do not get a solid centre, or you'll be up for a new gearbox :P
The other clutch to try is an Extreme clutch from adelaide clutchs, i've heard they are ok as well.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
