rs260 is basically running a gtr engine and drivetrain rs4 is rb25 with different drivetrain not as tough mostly autos and lower spec interior rs260 is manual only and has triple gauge cluster in the dash and piano finish black dash inserts vs silver on s1 rs4 and nicer trim on seats
https://www.sau.com.au/forums/topic/79942-rs4-v-260rs/#findComment-1455696
Rs4
4.3 diff ratios front and rear
single spinner rear diff
small n/a style axles on rear
small brakes (like tiny) on front and rear
different rear hubs with different shockies mountings
also i woulnt be surprised if the front axles are smaller than gtr ones :whatsthat
260rs
4.11 diff ratios front and rear
mechanical LSD rear diff
330mm rotors on front (back? im unsure)
brembo 4 spot calipers front and 2 spot rears
large gtr rear axles and all gtr running gear
aluminium hubs and gtr style mountings for shockies
trust me the stagea is far from a gtr with a rb25/auto in it thats for sure, they definately save some $$$ when choosing parts for the rs4's :confused:
autech is a killer and only issue i am having with rb26 in a stagea is the weight factor and 2.6L pulling 1900kg or whatever is quite difficult (even with 360-370rwhp) and im considering changing to the rb31 bottom end, but not sure at the moment, just wait and see :Pimp2:
cheers :cheers:
Brad
https://www.sau.com.au/forums/topic/79942-rs4-v-260rs/#findComment-1458461
Rs4
260rs
Brad
I thought the LSD was an option on the RS4 stageas - and it was standard on the series 2 manuals.
Apart from that, does anyone know if Brad's list above for the RS4 also applies to the series 2??? I haven't been able to find out anywhere on the web, but given they have the much better Neo motor & Turbo & Intercooler, did nissan put better axles/brakes/hubs on it as well?
https://www.sau.com.au/forums/topic/79942-rs4-v-260rs/#findComment-1459088
I've partly answered my own question by using the parts thread..
For the brakes - (front, then back)
WGNC34 RB25DET 25.4 CL28VF 42.8×2 280×28 AD11V 38.18 266×16
WG(N)C34 RB25DET 25.4 CLZ31VA 45.0×2 290×28 AD11VB 38.18 292×16
ie the series 2 might not have gone to the good x4 ones, but did get both bigger pads on the front, and bigger disks on the front and back...
https://www.sau.com.au/forums/topic/79942-rs4-v-260rs/#findComment-1459258
just finished complying R34 s2  sedan NON turbo :front  discs are 310 x 30 rear 295 x18 @
1430kg ...2.5 stagea seems to be a bit out of touch in the brake dept.. s1 and s2
brembo setup on 260 is brilliant .deals with weight pretty easy
I believe you (!) but those numbers are different to anything I've been able to find...
My understanding is that there wasn't a s1 and s2 version on the 260, there was only one version of it (ie they didn't do a r34 gtr based one)
https://www.sau.com.au/forums/topic/79942-rs4-v-260rs/#findComment-1459418
sorry meant s1 s2 of 2.5 stagea...
although the is s1 s2 260 but is just minor face lift ..lights in grill different bar and front indicators ..running gear is all the same
regarding the brakes on n/a 34 ...couldn`t believe it either ..same size as gtr r32 .... ..this sedan is a GT-V grade and was told by my supplier when I asked what is GT-V ...is turbo car ...without turbo..
it appears that this is correct
https://www.sau.com.au/forums/topic/79942-rs4-v-260rs/#findComment-1459530
VY 2003 commonwhore 3.8 v6 152kw @ 1526kg..just to keep things in perspective..
147kw @1430kg is sufficent for what it is.. a 4 door sedan
And things really in perspective :-)
Any commodore car: Piece of junk that really should be sent back in time to the late 70's, when it would then be accepted as 'ok'
R34 GTT 4 door - 206+kw, 1450kg. - 142Kw/ton
VY 2003 commonwhore 3.8 v6 152kw @ 1526kg - 99.6 kw/ton
R34 GTV 147kw @1430kg 102 kw/ton
So yes, it is better than a commodore AND has much better brakes/steering/suspension/ etc etc etc. No argument there.
But nothing like a turbo skyline!
The difference between a R33 GTT
180KW, 1400kg - 128kw/ton and the R34 is very very noticable, let alone the difference between the turbo and non turbo version!
https://www.sau.com.au/forums/topic/79942-rs4-v-260rs/#findComment-1460558
  • 11 months later...
Sorry to dig up a REALLY OLD thread, but I figure it is best to keep all of the info in the one place. Has anyone learned much about this in the past year? :D
How does the 260RS drivetrain compare to the S2 Manual?
Thanks :P
https://www.sau.com.au/forums/topic/79942-rs4-v-260rs/#findComment-2254298
    • So I'll put filler past the repair area a bit to make sure I don't miss anything. Then I'll block it until it's almost level, put the guidecoat, then keep blocking until it's gone. Then it's still wavy.  In regards to hitting the panel, I saw this video might give more context - Skip to 0:47 he knocks it down. But yeah I'm sanding until the guidecoat is gone then checking because otherwise my filler is still well above the bodyline. Unless what you're saying is I should put guidecoat around it early, surrounding the filler then stip once it's gone?
    • I refreshed the OEM injectors with the kit and connected it up. It now ideals okay even with the IACV removed. Driving still has the same cutoff issue like the 550cc injectors so the issue is somewhere else. I bought FPG's Fuel Pump Hanger. I will be installing it next, but it is not as straightforward as I thought it was with my limited wiring knowledge and no instruction on the specific model I purchased (FPG-089). I also got the incorrect billet clamp as I could not find info on the OEM sizing.
    • Stop looking at the garage floor, and turn the radio up a bit louder if there's any strange noises...
    • No. Turbo shuffle and surge/flutter are not the same thing. Specifically, on a GTR, turbo shuffle has a definite meaning. On a GTR, the twin turbos are assumed to be the same thing and to operate the same way, exactly. In reality, they do not. Their exhaust sides are fed and exhaust a little differently, to each other. Their inlet sides are fed and exhausted a little differently, to each other. Consequently, when they are "working" they are often at slightly different points on the compressor map compared to each other. What this means, particularly when coming on boost, is that one of them will spool up and start producing extra flow compared to the other, which will put back pressure on that other compressor, which will push the operating point on that other compressor up (vertically). This will generally result in it bumping up against the surge line on the map, but even if it doesn't, it upsets the compressor and you get this surging shuffle back and forth between them That is "turbo shuffle" on a GTR. It is related to other flutter effects heard on other turbo systems, but it is a particular feature of the somewhat crappy outlet piping arrangement on RB26s. There are plenty of mods that have been attempted with varying levels of success. People have ground out and/or welded more material into the twin turbo pipe to try to prevent it. Extending the divider inside it works, removing material doesn't. There are aftermarket replacement twin turbo pipes available, and these exist pretty mush purely because of this shuffle problem.
    • You can temporarily* use lock collars to keep it in place until you can do the bushes, back the nuts off, slide them in, snug back up. *temporarily is often for ever
