i spoke to bret over a year ago,he left the workshop of subzero a couple of years back and moved to gilmour developments in qld,turns out he was a bit shonky and brett was having dramas with the set up,the car itself went to the fabricators and got a chop up(3/4 chassis)nice big tyre was fitted and a bright yellow paint job,this car became a dedicated race car,he was so pissed off by the wait and trouble he was going to on sell the car to me once finished but havent heard from him in a year.
as for mick stanic he left his familys sub zero business and moved to adelaide to tillbrook performance shop as the head mechanic,though i have heard many stories about mick over the years which would steer me clear from him,but each to there own i guess.
i did have pics of the car which ill try to find and might i add its was looking hot,i ended up buying parts of try-09s of brett and its a shame why he got treated the way he does,he is very busy travelling up and down the cost working with his father in some type of earth drilling business.
theres a website he gave me which i will try to dig up,stay tuned.
https://www.sau.com.au/forums/topic/79977-try09s08s07s/#findComment-1455914
so its yellow now aye?
:confused:
omy08s u gotta vl drag car dont ya??? hows that goin?
car is almost ready just the little things you dont think about which im sure everyone misses out,like wiring,braided lines etc....im positive itll hit the dyno in about 4-6 weks then to the track it goes,if it runs into the 8s on its first meet ill be more than happy then we take it from there.....
as for try7s it is now bright bright yellow and looks great and is for sale if anyone is keen on a 7 second package in a 3/4 chassis skyline with an rb26 combo,all you have to do is find out where the hell brett is these days,until then good day.
https://www.sau.com.au/forums/topic/79977-try09s08s07s/#findComment-1456912
    • Just an FYI.. I installed a ECU Masters det3 piggback. For the next few years car will remain N/A but it has inbuillt 4Bar map sensor , boost control etc if we wanted to use it for turbo conversion when the time comes. Though the plan is to do a manual conversion and go to a link ecu when that time comes.
    • Do a degree in mechanical engineering specializing in combustion systems and materials. Learn how to actually wrench on things that don't require 70k+ USD buy-in while you're at it. You also want to learn to weld and machine. If you still want to do this then you'll nominally have the knowledge to actually do what you're thinking of doing. Whether you still want to do any of that once you've actually gone through that process is anybody's guess. Personally I cannot imagine anything more frustrating than trying to package a supercharger under the hood of any of these cars when the turbos are already fighting for every last inch.
    • That's a function of the fuel pressure reg, not the pump. The pump can do more, needs to be able to do more. The reg keeps the pressure in the rail constant above whatever the manifold pressure is.
    • You need enough post count to have PMs enabled. It will come. They are not the same. The NA box is the skinny little box and the turbo box is the big heavy one, and the yokes are not interchangeable.
    • So, you're not talking about rebuilding the dampers, just putting new tops on them? You just need new tops and a spanner.
