I used loctite on mine, as I couldnt click it off at 330ft/lb. I sparingly used loctite supernut lock which is the lower grade blue type.
I'd advise against using stud lock (red) or the retaining compound (green). I've seen bolts permanently attached with these grades. Once I saw a coarse threaded bolt that wasn't that much larger than the balancer bolt which we couldnt undo. Not with a 3/4" rattle gun, not with an 1" rattle gun and not even with an 1" rattle gun that used an 1" air line!!!
Note to self: Only use BLUE loctite!!
I really dont see a point in replacing the crank seal as its not leaking and would be more trouble than its worth IMO.. I am however doing the camseals and half moons, replacing the tensioner and possibly the bolt for the tensioner and the stud for the idler. The idler itself feels very smooth so im thinking not to bother replacing it... Any input?
Cheers,
Deren
Cheers,
Deren
You're better off replacing the idler. You'll kick yourself if you have to pull the whole thing down again in 10000k's if the idler gets noisy. They're only about $70 - do it now or suffer the pain.
Just posting these details as the search on this forum just sux now. Can't go past a couple of months.
BSC Motion Technology
3/ 1968 Hume Hwy Campbellfield VIC 3061
ph: (03) 9357 7515
Idler: NSK 56TB 2801 B01
Tensioner: NSK 60TB 0683 EA7L 806
Now I spoke to Steve when I got mine there and they were only about $120 for the pair. They apparently had hundreds in the warehouse.
Is it really important to torque the crank pulley bolt to exactly 446-466Nm?? Thats a huge amount of torque and the wrench needed would be very expensive. Im planning to buy a smaller one for lighter jobs but i cant even find some where to higher one like that. Someone said they just did it up as tight as they could, and it was ok. I'd prefer to torque it to the right tension but sounds as though it will be difficult...
Deren
Deren
Yea you need a 3/4 drive torque wrench , i have one but i'm in Sydney otherwise i would lent it to you .
As long as you do it up very tight with a big bar it should be o.k. , i always do them up with a torque wrench though .
  • 3 weeks later...
Recently put the crank pulley bolt back in and did it up real tight, now i cant undo it to make changes! I didnt think id need to undo it so i did it as tight as i could. I've already broken about 3-4 breaker bars!! Can anyone help me to get this bastard undone?? :(
Thanks guys,
Deren :(
Deren, maybe call lubemobile and tell them to bring a 3/4 rattlegun. Has to be worth paying for that. I have a heavy duty pulley pin spanner I made that should hold the load as well to make it easier and maybe you could buy a 3/4 breaker and socket.
I'd come and help but still recovering from back surgery.
Thanks again for the reply Geoff. Would a rattle gun fit in there with only the radiator removed?
    • Yes, I know🙄 but the sequential is not in my budget... don't want to reduce power neither, so looks like I'm stuck in the rabbit hole🤣
    • You’ll be very upset when you bust that too not to mention the gearing totally sucks. Don’t do it.
    • Is the panel filter one that is oiled? Have you ever cleaned or touched the AFM?
    • So.... the K&N air box thingo was too big, ended up gifting it to a mate, well, by gifting it he actually supplied food and beer at the pub,  which was nice, as it will not sit on a shelf in the garage for the next 10 years I did trim up some of the existing stuff to neaten it all up and gave it some wrinkle paint, unfortunately it currently has a used and abused mish mash of different types of hose clamps, 4 big fat T bolt type (shit), and a few normal clamps of vairing sizes and brands, but..... only until the 6 constant tension black worm clamps that I ordered from EFI solutions turn up next week Currently the current hose clamps are triggering me hard, LOL Is this the final version, probably not, I really want just 2 silicone pieces, a straight bit of silicone from the filter to the MAF is easy and will happen as soon as I head into Just Jap tomorrow, the problematic part is a 30° silicone bend from the MAF to the TB that I can connect the engine breather from the head, I found that there are bulk head fittings for boat bilge pumps that should work, but until I can get a 30° silicone bend the alloy pipe, and the 11ty thousand hose clamps, are there for the foreseeable future 4 hose clamps are golden, 6 are grudgingly acceptable, the 8 currently holding it all together is just taking the piss    I've also ordered 60 more retaining wall blocks for the front yard, I mis-gonculated the height that was required to get above the base of the Photinia's (red robin's) that are the hedge behind the front fence, currently it is 2 blocks high, and about 1/2 a block short, so going 3 blocks high will be above the base of the red robin's, and allow some room for mulch
