more pics and details here
1990 R32 GTR
129xxx kms (aftermarket dial, true kms unknown)
3 inch HKS stainless cat back
TRUST Pod filter's
Kei Office Coilovers
ROH 17inch wheels wrapped in 255's
Recaro front seats
15PSI
Wing removed
DBA cross drilled & slotted breaks (2 months old)
new bandix advance break pads (3 days old)
all new plenum gaskets $$$ (with receipts)
new 02 sensors (2 months old)
panisonic touch screen tv (folds out of dash)
DVD player, mini disk player, cd player
JVC rear and pioneer front speakers
autometer boost gauge
pivot turbo timer
front strut brace
driver and passenger recaro seats
razo pedels
bonnet pins
gold cam covers
plug cover removed
R33 GTR AFM's
new iridium plugs
comes with standard GTR wing
serviced and tuned at gavin woods and was told "its running exactly how a GTR should"
its also been compression tested and everything is fine..
i have the receipts for the work and compression results.
selling to buy something cheaper
i am looking for about $25500
(plates are not included, comes with 5 months rego)
https://www.sau.com.au/forums/topic/80335-1990-r32-gtr/
i have ordered a full turbo gaskit kit from nissan.. manifold > turbo & turbo > dump..
these will be put on on the weekend.
does anybody want to make an offer???
i have found a car i want but i have to sell this one 1st
i can remove some parts to make it cheaper.. like zaust (stocker will go on), seats (need your own to go on) boost gauge..
i will sell it with all the gear for 24500 if somebody wants to change the gasket themselves, otherwise il be doing it on the weekend.. i have already ordered the gaskets from nissan... they were $150
its a great looking car and will be missed! il even thro in a drift DVD for the drive home :D
https://www.sau.com.au/forums/topic/80335-1990-r32-gtr/#findComment-1474671
Any clear pics of the engine.
The rear spoiler. Has it got holes in the boot for it.
How are they plugged up?
Would you ship to WA?
PM Me
https://www.sau.com.au/forums/topic/80335-1990-r32-gtr/#findComment-1474797
PM Me
i have left the holes in the boot on purpose incase the new owner (or myself) wants to put the rear wing back on. ATM the holes are covered with red tape
i will talk to my Dad about shipping the car. i would obviously prefer to sell to somebody in QLD. but might be able to ship
ENGINE PICTURE
https://www.sau.com.au/forums/topic/80335-1990-r32-gtr/#findComment-1474909
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
