Im selling my commodore to buy a skyline!!!
Specs: 1998 series 1 VT Commodore Executive. ( With a HSV R8 255 Conversion)
Auto
Engine: HSV R8 255. Engine has done 14,000km when bought and done 2,000kms when pulled all a part and replaced with tuffer crank piston ring etc etc.
Interior: All stock!!,speedo reading is 144k kms but engine has only done 16,000kms.
System: Panasonic mp3 player 200watt,250watt aftermarket 6 inch door speakers,400wat weconic? amp rear mounted in boot,6x9 kenwood 320watt
Transmission: $3000 spent on hardening the auto for quicker response and to take more heat and HP on clutch plates and what have you not!! :)
The whole driveline changed to meet with the requirements to the conversion: tailshaft,diff,new radiator,3 inch hsv exhaust....
96% new tyres on rear and 78% near new on front
*With 12months rego!!*
$14,000 Marc 0433 188 182 plz sms as i work 12hr shifts or email me: [email protected]
Edited by sly40x
https://www.sau.com.au/forums/topic/80706-fs-98-vt-commodore-modd/
got any more interior pics?
I can post them up as soon as i take a pic of them, no ciggarette burns still in very great condition, just has seat covers over them!!
New price up this car has to go, its just sitting here wasting space, will soon be sold for parts if not sold whole!!
All it needs is a blue slip and regoed and you will own a fast car
$11.800 cant go wrong for a full sleeper
Bump
LOL ok no body serious to buy, well im going to register it.And to prove it will kill most of the mid range skylines on here im willing to run someone who wants to swap there R32 or R33 @ WSID one run fully paid for. If not will provide dyno sheet to go without the hassle, Marc
p.s if have to register will go back to original asking price as this car is a deadly sleeper!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
