- R33 Stock Cooler = Make an Offer
- R33 HKB Boss Kit (GTR) = $30.00
- Apexi Coilovers (FullSet)(NoLeaks)(LikeNew) = $1000.00
- Tein Coilovers (FullSet)(NoLeaks)(GoodCondition) = $900.00
Note: No Pics of coilovers as both sets are still on the cars.
- AutoGauge gauges (BrandNew)(Smoked Series. Looks like Defi black faced gauges):
Digital Air/Fuel ratio = $60.00
Boost = $60.00
Oil Pressure = $60.00
Oil Temp = $60.00
- Sports Steering Wheel (GC)(Old School style) = $50.00ono
- Triple gauges holder for din slot (BrandNew) = $30.00
- 5" AutoGauge Monster Tacho with external shift light (BrandNew in Box)(Silver Faced) = $150.00
- Walbro Fuels Pump (BrandNew) = $150.00
- AudioLine 2 channel Mono Block (BrandNew in Box) = SOLD
- MTX 12" SubWoofer (BrandNew) = SOLD
:chairshot
https://www.sau.com.au/forums/topic/80796-~just-some-stuff-needing-to-clear~/
Hey mate,
If you hold onto that 5" Monster tacho for me, for two weeks, i will buy it off you.I'm not mucking around here, hold it for two weeks, and i'll buy it off you. Is it possible to sell it for $130?if so then a week and a half.Also does it come with mounting bracket? Also where is your location?
Cheers
Kory
What size gauges does the gauge holder for din slot hold?
Please send pics of:
Digital Air/Fuel ratio = $65.00
Boost = $60.00
Oil Pressure = $65.00
Oil Temp = $65.00
To: [email protected]
Cheers,
Greg
