  • 2 years later...
Nissan Skyline GT-R V-spec II R34
The GT-R V Spec II has the ATESSA E-TS PRO four-wheel drive system which integrates with the LSD, giving the computer control of side-to-side torque distribution as well as front to rear. This offers improved traction. Underneath the V Spec II, Nissan have fitted front and rear diffusers which work together to smooth airflow under the car, reducing lift and creating down-force. The rear diffuser is made of carbon-fibre and features a NACA duct to direct cooling air to the rear differential. The V Spec II also has a different 2-step tachometer which has finer graduations above 3,000rpm for more accurate readings.
Nissan Skyline GT-R V-spec II N1 R34
The GT-R V Spec II N1 is designed to be the basis of racing GT-Rs. It features different turbo chargers using metal rotors instead of ceramic, an engine oil cooler and larger diameter rear brakes. To save weight some items are removed including the rear wiper, rear fog lamps, the remote control entry system, air conditioning and the audio system (although the antenna and wiring harness remain). The centre console lid and parking brake lever are now trimmed in plastic rather than leather and the external mirrors are painted black. The N1 is only available in white with an unpainted lightweight carbon-fibre bonnet.
Nissan Skyline GT-R M-spec R34
Released in 2001, the M Spec is similar in specification to the V Spec II but with a few differences. These are mainly inside the cabin where the M Spec has a leather covered steering wheel and gear knob with gold stitching and heated leather seats. Other changes include an aluminium bonnet and revised suspension tuning. Like the V Spec II, the M Spec has the ATTESA E-TS PRO four wheel drive system, underbody aero package and a 2-step tachometer.
https://www.sau.com.au/forums/topic/8103-m-spec/#findComment-1158723
    • Hi all,   long time listener, first time caller   i was wondering if anyone can help me identify a transistor on the climate control unit board that decided to fry itself   I've circled it in the attached photo   any help would be appreciated
    • I mean, I got two VASS engineers to refuse to cert my own coilovers stating those very laws. Appendix B makes it pretty clear what it considers 'Variable Suspension' to be. In my lived experience they can't certify something that isn't actually in the list as something that requires certification. In the VASS engineering checklist they have to complete (LS3/NCOP11) and sign on there is nothing there. All the references inside NCOP11 state that if it's variable by the driver that height needs to maintain 100mm while the car is in motion. It states the car is lowered lowering blocks and other types of things are acceptable. Dialling out a shock is about as 'user adjustable' as changing any other suspension component lol. I wanted to have it signed off to dissuade HWP and RWC testers to state the suspension is legal to avoid having this discussion with them. The real problem is that Police and RWC/Pink/Blue slip people will say it needs engineering, and the engineers will state it doesn't need engineering. It is hugely irritating when aforementioned people get all "i know the rules mate feck off" when they don't, and the actual engineers are pleasant as all hell and do know the rules. Cars failing RWC for things that aren't listed in the RWC requirements is another thing here entirely!
    • I don't. I mean, mine's not a GTR, but it is a 32 with a lot of GTR stuff on it. But regardless, I typically buy from local suppliers. Getting stuff from Japan is seldom worth the pain. Buying from RHDJapan usually ends up in the final total of your basket being about double what you thought it would be, after all the bullshit fees and such are added on.
    • The hydrocarbon component of E10 can be shittier, and is in fact, shittier, than that used in normal 91RON fuel. That's because the octane boost provided by the ethanol allows them to use stuff that doesn't make the grade without the help. The 1c/L saving typically available on E10 is going to be massively overridden by the increased consumption caused by the ethanol and the crappier HC (ie the HCs will be less dense, meaning that there will definitely be less energy per unit volume than for more dense HCs). That is one of the reasons why P98 will return better fuel consumption than 91 does, even with the ignition timing completely fixed. There is more energy per unit volume because the HCs used in 98 are higher density than in the lawnmower fuel.
    • No, I'd suggest that that is the checklist for pneumatic/hydraulic adjustable systems. I would say, based on my years of reading and complying with Australian Standards and similar regulations, that the narrow interpretation of Clause 3.2 b would be the preferred/expected/intended one, by the author, and those using the standard. Wishful thinking need not apply.
